  #31
Old 08-22-2022, 04:04 PM
EddieJones's Avatar
Default Re: EuCon crashes overnight, every night
Originally Posted by Eric Lambert View Post
I have to say though... I've still not had a EuCon crash since upgrading the OS to 12.5.1. Seems that that took care of whatever was causing the issue.
Big Sur was the same....until .4 came out and fixed it.
  #32
Old 08-23-2022, 10:03 AM
reichman's Avatar
reichman reichman is offline
Are you now running Eucon in Apple Silicon mode?
Nathaniel Reichman
Producer/Re-recording Mixer
Dubway Studios | Rhumba
14 East 4th Street, Suite #602 | New York City
  #33
Old 08-23-2022, 12:10 PM
thebeatless thebeatless is offline
Originally Posted by EddieJones View Post
If it's that bad, then the logs will help. Please use the Collect logs option from the EuControl menu and upload them somewhere and send me a PM with link. Others(and our testers) do not see it like that, so there must be something else up on your system. I presume you have tried a full uninstall, reboot and reinstall, inc. checking remove all prefs?
Edit: If this all started since getting the Mac Studio.....did you do a migrate? This has known issues.
Sorry, I'm just now seeing this.
I don't see "collect logs" in the Eucontrol menu.
I reluctantly and regretfully did a clean install. haha. Everyone here said I was having performance issues because I initially migrated. Funny enough, everything behaved exactly the same after spending several hours installing my ridiculous collection of plugins. But.... Eucon actually worked great when running the system from my migration. Since clean installing everything I've had constant issues. I keep hoping an update will be released and take care of it!
I've uninstalled/reinstalled multiple times.
No change here with latest Monterey and IOS.
Thanks!
  #34
Old 08-24-2022, 10:23 AM
EddieJones's Avatar
Thanks!
There is no update to fix this as it's not a EUCON issue (other than the having to run EuControl in Rosetta which we are working on). If you are not seeing the Collect Logs from the EuControl notification icon menu then you must be running a very old version of EuControl.
  #35
Old 08-24-2022, 01:49 PM
Eric Lambert's Avatar
Yes. Rosetta is unchecked.
  #36
Old 08-24-2022, 01:57 PM
You had constant issues after the migration too, which is why you did the clean install. If problem persist after a clean install then you have deeper issues and you need someone to take a look at that computer in general. Very little useful data related the issue is being offered outside of the quest to prove that there was nothing wrong with the migration, though, very clearly, quite a lot was wrong, and still is.
You have people here who could actually fix the issues. Cut the games and allow them to help find the culprit. I can tell you that most have simply stopped responding to your complaints because you're unwilling to do anything about it.
  #37
Old 08-24-2022, 02:13 PM
You were one of the people arguing with me about clean installing. I'm not playing games, once again I'm simply sharing my experience and hoping for a solution.
My issues were only performance issues after the migration, but they weren't issues that were solved by reinstalling everything. Sessions from my 2020 iMac could not play on the studio ultra. There has been some improvement after recent pro tools updates though. I'm now able to play sessions with similar routing/processing.
  #38
Old 08-24-2022, 02:17 PM
I was looking in the menu at the top left of the eucon application, not the Notification icon menu on the top right of the menu bar. That's where I was confused. Now that I know where to find it, I'll get it to you now, although I don't know if I should wait until right after a crash. It's been sitting idle for the last few hours.
Fire tablet goes offline overnight, every night Eric Lambert Avid S1, S3, Dock and Control App 8 10-22-2020 12:45 PM
Powering off S3 crashes Eucon ulisauer Avid S1, S3, Dock and Control App 12 10-22-2019 08:59 AM
Eucon crashes planck Avid Pro Mixing General Discussion 23 09-14-2018 10:20 AM
Cubase Crashes from EUCON aptmusic9 Artist Series 0 06-05-2014 09:40 PM
eucon 3.0 crashes tandri79 Artist Series 7 06-24-2013 02:24 PM
