Old 07-02-2003, 07:33 PM
digi2000 digi2000 is offline
Default Midi I/o not appearing In Pt 6.0
I Just installed 6.0 seems to work fine. That said. My Midi I/O is no\t coming up at all. I can't even see it being found when pro tools is being loaded. I just installed the new drivers. and still nothing any hints.
Old 07-02-2003, 09:23 PM
Milamber Milamber is offline
Default Re: Midi I/o not appearing In Pt 6.0
digi20000,
I have my MIDI I/O working with MIDI I/O driver 2.0.1cs2 running PT 6.01 under OS X 10.2.4. Here is what I did to get it working:
1. Installed MIDI I/O driver 1.5
2. Rebooted
3. Ran the MIDI I/O OS X firmware update that was installed with the driver.
4. Installed MIDI I/O driver 2.0.1cs2
5. Rebooted
6. Ran "Audio MIDI Setup" (in Applications folder->Utilities)
+ On the "MIDI Devices" tab, I see a "MIDI I/O 1"
+ I clicked "Add Device" and defined devices for each external MIDI device I have (i.e. DX7, ddrum4, SoundCanvas, etc.) and dragged connections to/from the in/out ports for each device and the MIDI I/O.
+ Quit Audio MIDI Setup
7. Run Pro Tools and you should be able to see the MIDI devices you added.
I hope this helps! Let me know if you have any questions.
Mark
Old 07-03-2003, 06:25 AM
I did do all of that, the problem I ran into was with the firmware update. It kept looking for some scripting program and would not open. I am not a mac expert, I kept trying to open it and it just errored all the time
Old 07-03-2003, 07:17 AM
once I get the midi tab open there is absolutely no sign of the Midi I/O at all
Old 07-03-2003, 02:35 PM
I am running 10.2.3 Jaquar
When I try to open the firmware update it says it cant find the scriptiing editor. I also renamed it and now everytime I re download it it is renamed.
when I originally downloaded it, it asked me for an application to open it so I choose a scrip editor and I have been ^%$#@%^ ever sinse.
Any suggestions. I am a very weak mac user
Old 07-03-2003, 07:13 PM
We need to figure out how to get your MIDI I/O firmware updated. I think that once you do that, it will work.
Do you have an OS9 partition that you can boot to? (Check out the System Preferences->Startup Disk). According to the MIDI I/O documentation, if you install the OS9 drivers, they will automatically update the firmware. Then you could boot back into OS X (via OS9 Control Panel->Startup Disk).
Or you could try updating to a newer version of OS X 10.2.x. I am running 10.2.4 and it looks like PT 6.1 will require at least 10.2.6.
Do you know anyone else with a Mac that could help you? Or you upgrade the firmware using their system.
Old 07-04-2003, 01:57 AM
<font size="2" face="Verdana, Arial">What error are you getting when you run the firmware update? Also, what version of OS X are you running?
Old 07-04-2003, 09:28 AM
Hey thanks for the advice, I spoke to Digi last Night and yes I did need to go into 9 and update the Firmware. and install the drivers. I then went back into 10 and did the same. Works like a charm. Then I did the Upgrade from 6 to 6.01 and now I am not able to get the Control 24 to work. Eerytime I scan for it. It comes up in the menu but then when I hit Ok it says it can't find it and wants me to put its personality file in the controler folder.
1) WHAT IS THE PERSONALITY FOLDER
2) WHERE IS THE CONTROLLER FOLDER
Thanks in advance
Old 07-04-2003, 02:34 PM
You're welcome. I'm glad to hear that you got it working.
Mark
Old 07-07-2003, 07:00 AM
P.S I also fixed the control 24 problem. Basically I downgraded to PT 6.0 and everything worked fine.
MIDI Controllers Not Appearing In Peripherals List TaoMokoda Pro Tools 10 15 06-14-2024 08:55 AM
No Midi Appearing In PT 8 Hodaka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-18-2012 03:57 AM
MIDI Problems Multiple X Note Appearing Griffin23 MIDI 2 08-27-2010 02:57 PM
Ghost midi regions appearing jackruston MIDI 4 07-18-2001 03:30 AM
Ghost Midi regions appearing Barry Young Pro Tools TDM Systems (Mac) 0 05-27-2000 02:29 PM
