  #181
Old 05-09-2024, 04:20 AM
aand aand is offline
Default Re: New Sound FX Library!
The independent sound community returns with 20 new sound effects libraries here:
For sounds of nature, gear up for winter with the chilling snow and ice textures, take a walk through lush nature loops, or create tranquil gurgling soundscapes.
For specific media, we have ethereal sounds of the cosmos for sci-fi soundscapes, dynamic anime motions, a female British detective voice collection, a diverse library of magical spells, and a fun retro pixel game sound effects pack.
For the gearheads, we've got the rumbling purr of a Honda Transalp XL750 motorcycle, a nostalgic 2006 Kia Ceed compact car, and detailed interior car ambiences while on the road.
If you are looking for Foley and textures, check out the rhythmic hums of a mechanical pencil sharpener, the clickety clacks of buttons and switches, realistic sounds of bowling, fun popping toy foam blasters, haunting wind and metal, diverse modern and antique doors, and creative textures that transform everyday objects into instruments.
And if you need that perfect whoosh, we have soaring transitional whooshes, as well as a massive collection of whooshes that covers everything from magic and sci-fi to vehicles and character movements.
Hear all the new sound effects libraries here
_
  #182
Old 05-09-2024, 03:08 PM
subbasshead subbasshead is offline
Two new HISSandaROAR libraries released!
From an actual independent sound library business
FX022 BODY FALLS
https://hissandaroar.com/v3/soundlib...22-body-falls/
Our crash test dummy has been falling over a lot recently – mostly outdoors. He’s been falling over on the driveway,
the lawn, concrete path, in gravel and into bushes, ferns, branches and forest debris. A few ‘body drags’ were also
recorded on gravel, as useful elements.
Some falls down a flight of stairs also created some great thumpy interior tumbles & falls.
It’s hard work throwing around a 20kg boxing bag wearing overalls, augmented with pumpkin, potatoes,
a pool noodle and some gloves. This is the third evolution of this method...
NOTE: 33% discount expires in 48 hours
Check out the making Of vid:
https://www.youtube.com/watch?v=9J10j1VqrTo
FX023 STAB SLICE
https://hissandaroar.com/v3/soundlib...23-stab-slice/
NOTE: 33% discount expires May 18th
https://www.youtube.com/watch?v=APqmVtiOHGE
This library is based on an idea I came up with while working on the film THE WARRIOR’S WAY
which involved a lot of Samurai sword fighting action. We recorded swords chopping & slicing vegetables,
but there were so many decapitations in the film I wanted more variety…
And more grit! Especially when needing to ‘cut through’ loud action music!
What I found was that slicing a sword through sand produced an interesting sound,
which could be varied depending on the sword or object used and the texture and density of the sand.
For this library I expanded the concept.
After recording a range of weapons on location in a sand dune, I then collected up
buckets full of sand, fine base metal, gravel and tiny stones and recorded them in my foley room.
Slowly grinding a sword into gravel sounds excruciating, especially imagining it augmented with some
Vegetable Violence squelch and/or Slime Moves.
I also recorded versions after wetting the sand and gravel…
And those stabs and slices sound even more gruesome!!
  #183
Old 05-30-2024, 04:21 PM
New Multitrack Vehicle Library: VEH003 TRAILER ONBOARD
https://hissandaroar.com/v3/soundlib...ailer-onboard/
A car trailer was rigged with six mics and my Sony a6300 camera:
- Sennheiser MKH8040 LR, one close up on each wheel
- Sennheiser MKH8020 pair sheltered LR behind the wind shield
- Sennheiser MKH8050 sheltered centre behind the wind shield
- LOM Geofon on chassis, capturing rumble.
The surfaces driven on include:
- up & down my driveway, scraping plants & bushes
- suburban driving 0-50kmph (0-30mph)
- suburban arterial route driving 50-70kmph (30-45mph)
- highway driving 90kmph 55mph
- gravel road driving 0-50kmph(0-30mph)
- driving over multiple judder bars/speed bumps 0-10kmph (0-5mph)
Making Of video
https://www.youtube.com/watch?v=OSAEFtoGYOg
33% discount expires June 9th.
  #184
Old 06-06-2024, 08:35 PM
If you're someone who wonders why people bother recording at high sample rates,
check the FFT at the link below, captured with Sanken CUX100K microphones at 192kHz.
Note how the spectrum of the sounds goes way past human hearing at 20kHz, and past 50kHz right up to 96kHz...
This is a little sample from a new HISSandaROAR sound effects library:
UFX032 PRESSURE Stop Release
https://hissandaroar.com/v3/soundlib...-stop-release/
This library is an idea found while working on a different library, experimenting with
negative pressure (ie suction) and positive pressure. I noticed that when some rubber sheet
or plastic suddenly blocked the suction, it created a solid ‘thump’ when pulled free.
The rapid release of pressure seemed interesting and lit up my subwoofer!
So I collected up all the accidental pressure suction stops & releases from those recordings
Then I set about exploring this one specific technique, purposefully restricting suction and then
restricting positive pressure from my compressor, creating very sharp transients and spectrum up to 96kHz.
As with IRs and convolution, the ‘noise’ aspect of the sounds means they respond strongly to processing.
If you'd like to have a play with these sounds, I've launched a little sound design challenge
Using 5 x 192kHz sounds provided, make something extraordinary & send me a link!
I'll give away as many copies of the full library as there are extraordinary entries.
Download here:
https://hissandaroar.com/v3/sound-design-challenge-02
Deadline June 16th!
  #185
Old 06-14-2024, 04:08 PM
New HISSandaROAR Ambience Library:
BEACHES THREE
https://hissandaroar.com/v3/soundlib...beaches-three/
Beautiful natural ambiences recorded by a human. No AI. No LLMs.
51 x 24bit 96kHz stereo WAV files = 11.26GB
33% intro discount until June 16th
Making Of vid:
https://www.youtube.com/watch?v=cEpuXcGO3mY
  #186
Old 06-17-2024, 03:53 AM
evs evs is offline
ROOM TONES
Residential Room Tones.
The quiet presence of indoor air.
We are running an early Bird discount until JUNE 25th 2024!
Get it here:
https://tonsturm.com/soundpacks/room-tones/
TRAILER
Introducing our latest ambience library, focused entirely on room tones.
Room tones are essential for every indoor scene - they’re subtle but vital.
We've captured the room tones of residential buildings across rural, suburban, and urban environments.
We’ve recorded kitchens, living rooms, children’s rooms, bathrooms, basements, hallways - you name it.
(If you want bigger rooms, our “dark ventilation” soundpack may be what you need.)
We put a lot of effort in to get the pure room tone. But we also included single events
These events are carefully edited cutouts from the room tones, featuring various external sounds like cars passing by, traffic, airplanes, walla and neighbour rumble, to enrich your atmosphere when needed.
And… this soundpack is massive.
There are 130 room tone files.
And 42 event files.
3D Audio
Pleasingly wide and deep sound images, that will flatter your ears, and set you directly into the sound.
This is what you get with ambiences recorded with our new 7.0.2 Rig.
Wide spaced omnis and a nice hight layer lets you experience the ambiences as if you are there.
We here at TONSTURM love time of arrival stereophonie, and we love immersive 3D audio.
7.0.2, with 7 x Sennheiser mkh8020 und 2 x mkh 8090.
Needless to say that this rig also records a beautiful 5.0, and we also offer a nice stereo mixdown.
Get it here:
  #187
Old 07-05-2024, 05:30 PM
Two new HISSandaROAR sound libraries just released:
VEH004 TRAILER IMPACTS
= hefty multitrack metal impacts
https://hissandaroar.com/v3/soundlib...ailer-impacts/
Making Of vid:
https://www.youtube.com/watch?v=zpQHTtUCW7o
And a new Impulse Response library:
IR005 SPRINGS
https://hissandaroar.com/v3/soundlibrary/ir005-springs
First capturing IRs from my studio (AKG BX5, Vermona Retroverb, Roland Space Echo 201
& Chorus Echo 555, Doepfer A199.
Second, IRs in springs ranging from 3.4m long to 140mm.
Third capturing IRs from resonant wireframe objects.
Discount available on both until July 14th!
  #188
Old 07-18-2024, 02:15 PM
Had fun making this new UI sound library!
HISSandaROAR FX024 UI SNIP
Check the vid - thanks to @xlnaudio for their great browser
https://www.youtube.com/watch?v=ETfBAmjhQ3A
33% discount available until July 28th
https://hissandaroar.com/v3/soundlibrary/fx024-ui-snip/
Also just launched a #soundesign challenge
Make something interesting with some provided 24/192k Contact Mic recordings
& be in to win a free copy of the next library!
Free download here:
https://hissandaroar.com/v3/soundlib...-challenge-03/
File Type: jpg CONTACT_MIC_HISSandaROAR_SDC03_HRTP.jpg (53.5 KB, 0 views)
  #189
Old 08-08-2024, 04:56 PM
HISSandaROAR 14th Birthday Sale
started on August 8th: 808 day!
So we released a new library to celebrate: SD068 SUB BASS
https://hissandaroar.com/v3/soundlibrary/sd068-sub-bass
Sub bass tones, booms, 808 kicks & pitch bends & dives captured from my modular synth...
Check the Youtube video:
https://www.youtube.com/watch?v=JU-qlDTGcqM
Our 14th Birthday Sale runs until end of month
with 50% off every sound library!
https://hissandaroar.com/v3/all-sounds/
  #190
Old 08-22-2024, 03:53 PM
The last rites of my old SUV = a new HISSandaROAR sound library:
VEH005 WATER BLASTER ON SUV
https://hissandaroar.com/v3/soundlib...blaster-on-car
They warn you not to use a Water blaster or Power washer on your car as it wrecks the paint…
Challenge accepted!
Check the Making of vid:
https://www.youtube.com/watch?v=eoIfvDetE-0
This new library and all 160 sound libraries are on sale with 50% off until end of the month! Also...
COMPLETE 160 is also on sale!
Both download and on HD
https://hissandaroar.com/v3/complete/
[IMG] code is Off
Downloadable Sound Library Nick10101 MIDI 0 06-14-2010 12:39 AM
Does ProTools come with a sound library? scleroshock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-29-2009 11:20 AM
Sound FX Library - Recommendations Mubeau Post - Surround - Video 7 10-21-2008 10:41 AM
Sound fx library recommendation! javi79 Post - Surround - Video 8 05-14-2008 11:59 AM
Looking for a sound library with ... soundthinker Post - Surround - Video 2 03-28-2006 08:51 AM
