digi core driver FIXED ...
hey guys,
i have lost the ability to use core audio driver 6.7 on HD system with itunes, garageband, logic ... anyone else have this problem .... direct I/O with abelton live works fine .... just wanted to add that ... i have reloaded the 6.7 core driver and uninstalled and loaded 6.5.2 to no avail .... i am now on 6.7cs8 and 10.3.7 ... info below is not updated yet thank you john digi core manager was stuck at 96k .... reset to 44.1 in hardware setup , restart and all is well ..... i work at 96k all the time but i did not expect the core manager to not be able to change with the program that is using it .... Digi thank you for responding to my post ... i had tried reinstalling .... peace john
Re: digi core driver
Try deleting Digisetup.OSX and DAE Prefs (folder) from:
MacHD>Users>your account>Library>Preferences Empty trash, restart and try it all again. |
done all that .....
repair permissions ... reload drivers ... thrown away all prefs ..... thank you
This happened to me recently, and I ended up opening the audio midi setup (applications/utilities/audio midi setup) and reselected my hd i/o as my audio out. It somehow mysteriously changed on me.
-FB |
tried that to no avail ... still not working ....
anyone else thank you for the replies guys ... this sucks john
do you have a sync i/o? if so, maybe you have a clocking issue. or are you running the 192 or 96 i/o as internal?
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
What happens when you launch the core audio manager application? Is sound output defaulting to built-in Apple hardware? What happens exactly when you attempt to use iTunes with the Digi Core Audio driver?
You may want to delete Library > Audio > Plug-Ins > HAL > DigidesignCoreAudio.plugin and then reinstall it. Hope this helps, Digidesign Technical Support |
Re: digi core driver FIXED ...
see solution in bold in my original post above ...
thank you to all for your help peace john
I also have an issue with core driver. When I install on my 1.25 Alluminium Laptop I cant hear the modem or dial tone any more, any ideas?
www.stevescanlon.com |
Digi Core Audio Driver | nate9 | macOS | 3 | 03-23-2013 06:43 AM |
PLEASE tell me Digi has fixed the Wave Driver!!!!! | Tunekicker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 03-25-2007 12:35 AM |
digi core driver 6.5.2 question | julien-k | Pro Tools TDM Systems (Mac) | 1 | 09-26-2004 02:23 PM |
Digi ....Core Audio Driver | archtop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-30-2003 07:30 AM |
Bug in Digi Core Audio Driver? Driver update coming? | mgbasinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2003 08:59 PM |
