Protools Video Black screen while playback with no noticiable avid video engine error
Everything was working fine with videos imported into Protools 2022.7 (in windows) but out of nowhere, every video imported into a protools session can’t be seen while playback. It only shows a black screen in the video window inside protools.
I tried everything I could think of. Here is a list of what I’ve tried: 1) change protools version from 2021.7 to 2022.7 2) disable and re-enable avid video engine from playback engine option. 3) check a variety of video formats and codecs 4) double check that the session frame rate setup matches video framerate 5) change video drivers installed in windows 6) verify that video files does not have non-standard characters in their names 7) clean uninstall and reinstall protools I have found someone that had the same problems but in MacOS and they solve it by deleting to folders. However, one of these folders doesn’t exist in windows. Please need help with this. Thanks in advance Enviado desde mi iPhone utilizando Tapatalk |
Re: Protools Video Black screen while playback with no noticiable avid video engine e
Zero system info……
https://duc.avid.com/showthread.php?t=300050 |
1. Go to C:\Program Files\Avid\AVX2_Plug-ins and empty the contents of this folder.
2. Go to C:\Users\Public\Documents\Avid Video Engine and empty the contents of this folder, but DO NOT delete the actual folder - or PT video engine will not start. (Avid FatalErrorReports will repopulate after you reboot pro tools) 3. Restart PT 4. Go to Preferences/Operation in PT and uncheck 'Enable GPU' After much frustration this solved the issue for me - and I now believe that the 'black screen' issue has something to do with the 'Enable GPU setting' - which might be preventing video playback. Hope this helps! |
Hi there I hate to hijack the question, but what about the same folders for Mac that are supposed to be deleted? I am on an M1 Mac specifically. I have tried deleting those folders before and they repopulate and I have the same issue. Is it normal for those folders to repopulate in the same location on my computer? Thanks!
Hey there - to my knowledge, the 'Avid Video Engine' folder itself should repopulate automatically on Mac, but the only folder that should repopulate within that after clearing it is 'Avid FatalErrorReports'.
Is the 'AVX2_Plug-ins' repopulating too? Have you tried disabling the 'Enable GPU' setting? |
Thanks a lot for your help. Here is an update to the problem and a possible solution. It seems that this problem has something to do with AMD video card drivers. I have to install the recommended previous AMD Adrenaline Video driver, which is v. 22.5.1 (not the last one) in order to partially fix the problem. Now I can import and see the videos but I cannot import the audio from the video because protools crashes. And when I import a video I have to close session and reopen it, otherwise the video produce playback errors and delay in the commands. I hope this helps. Enviado desde mi iPhone utilizando Tapatalk |
Hi, welcome to the community luisaudio.
Please be aware that whenn you use tapatalk as a newbie, your posts will go to manual approval until "good" post count is reached.
Thanks, jab
Current system: Pro Tools Studio annual Windows 10 Pro MSI home build 11th Gen Intel i7-11700K @ 3.60GHz 32g RAM, 6Tb SSD AVID Dock w/Android 10" Tablet IK Multimedia AXE I/O Behringer U-Phoria UMC1820 USB Audio Interface Bakerplace.net A place for Audio/Video Post Production. |
Video Engine "Network clock is not locked" error when screen sharing video over skype | piuretig | Post - Surround - Video | 0 | 01-12-2022 01:37 PM |
Video Black Screen During Playback in PT 2020.9.1 | josoro505 | Post - Surround - Video | 2 | 10-24-2020 02:29 PM |
Black Video Screen Playback | George2000 | Pro Tools 2018 | 0 | 04-24-2019 07:25 AM |
No Video Playback (Black Video window and thumbs) | winkelement | Pro Tools 12 | 13 | 03-17-2016 11:03 AM |
AVID video engine playback issue | Audio_Vision | Pro Tools TDM Systems (Win) | 4 | 04-08-2011 01:09 PM |
