Pro Tools 7 & RTAS Instruments not working
Hi
I seem to be having a problem with pro tools 7 and rtas instruments. The spectrasonics atmosphere and trilogy, as well as native Komplete 2 do not produce any sound in 7. Any ideas or advice. I already havethe latest available updates. cheers wiggzaro |
Re: Pro Tools 7 & RTAS Instruments not working
You have to ensure that the Instrument or Aux that has the Trilogy etc. inserted has an input selected. Such as "ADAT 1 in" or "Analog 4 in" or the like. It won't make a sound without an input selected.. All the best, Big D
INTEL QUAD XEON INTEL S5000XVN serverboard 4 gig Fully Buffered Ram (About to add more) 3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green NVIDIA Geforce 7300le, Command 8,HD2,192,Massive Pack 4 Windows 7 64 bit PTHD 9 |
This is the 4th new post this week on this topic. I guess Digidesign expected that people would read the "readme" before they started working with new software?
Digi - this question probably deserves a sticky until 7.0.1 - I can only imagine the number of support calles you guys are getting on this one issue. from the PT7 readme: Quote:
--Jeremy |
Your wish is my command.
Just another friendly reminder to read the manual or, at the very least, the Read Me files that are installed with the Pro Tools 7 upgrade. They have all kinds of useful info.... |
Hi Guys
thanks for the coments. I actually found the solution on the duc yesterday after I'd posted the note. The readme files explain qite clearly and I was very relieved to find the solution. (I was dreading the thought of having to downgrade again after so much anticipation) thanks again wiggzaro |
Do these people want everything!!! |
hi a have the same problem whith RTAS/instrument in PROTOOLS 7.
i talked whith dan santucci at nativ instrument and he said that this.. is an issu of ProTools backwards compatibility whith older RTAS plug/ins.Only new RTAS instrument will allow monitoring on AUDIO tracks. |
And more, what instrument are you trying to use that isn't working? Best Regards, John
****************** John Rammelt Producer / Composer / Post Hajp AB old site: Soundfactory JPR |
Some RTAS stuff is very stabile. Impact! and NI's B4 II, the M-Audio stuff demonstrate to me that it's really a third party issue...and some seem better than others. Arturia is one of the worst, the more so because their stuff sounds cool...I have been unable to use ANY of their VI's without constant crashes...CS80, with its' so-called PT7 version is completely out of the question. MOTU is a little better...Symphonic instrument's new rev seems OK, Mach5 is so-so. You need to reduce buffer sizes to cut the midi stuff, then raise it to help with stability. I wish there was at least some third-party standard for RTAS, some developer guidelines...and i wish that companies like Arturia would FIX what they've got before rushing to make new, broken instruments.
Go on then and put us out of our misery!!!
WHAT DOES IT SAY IN THE "READ ME"?!!!!! |
MDW Hi-Res Parametric EQ 3.0 (TDM/RTAS)not working in pro tools 9.0.2 | odeu87 | Pro Tools TDM Systems (Mac) | 0 | 04-10-2011 06:34 AM |
64 Bit Pro Tools? RTAS Working on ALL Cores? | Bentley Ferrari | Pro Tools TDM Systems (Mac) | 45 | 03-31-2009 09:24 AM |
PT8 and RTAS instruments... is it better?? | nayrbnoswal | Pro Tools TDM Systems (Mac) | 9 | 12-19-2008 06:22 PM |
PT 7 RTAS - SOME INSTRUMENTS NOT WORKING | MESH@ZU | Pro Tools TDM Systems (Mac) | 7 | 11-08-2005 04:41 PM |
RTAS instruments in PT 7 | Stig Eliassen | Pro Tools TDM Systems (Mac) | 5 | 11-04-2005 02:30 PM |
