  #21
Old 05-04-2021, 08:24 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: PT HDX Cheese Grater roll call
Originally Posted by stargazer View Post
I’ve read so much about difficulties with power connections and compatibility, especially when it comes to single slot cards.
Exactly what brand and model are your RX570?
It's pretty complicated as there are many cards with almost the same name, mine is this one:
https://www.sapphiretech.com/en/cons...se-rx-570-8gd5
Named on the Sapphire website as: PULSE RX 570 8GD5
Make sure it's NOT the PULSE RX 570 8G G5
and NOT the PULSE RX 570 8G G5 HDMI DP
On the box it says:
EAN 4895106289420
SKU 11266-78-20G
AFAIK this is one of the very few metal compatible cards, able to run under High Sierra (you need to install High Sierra with your old GPU and then insert this one), and with a single 6 pin connector.
I paid under 200 euro's few months ago, but due to the crypto mayhem these are all out of stock or over 600 euros each.
  #22
Old 05-04-2021, 09:12 AM
stargazer stargazer is offline
Originally Posted by dr sound View Post
I purchased 3 NVIDIA Quadro K5000 4 Gig Video cards.
Those two slot cards doesn’t fry the HDX cards?
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
  #23
Old 05-04-2021, 09:17 AM
On the box it says:
EAN 4895106289420
SKU 11266-78-20G
What version of macOS are you running?
  #24
Old 05-04-2021, 12:07 PM
Farhoof's Avatar
High Sierra
  #25
Old 05-04-2021, 01:01 PM
High Sierra
I see.
The reason for me to get a Metal compatible gpu would be to run Mojave or higher.
  #26
Old 05-04-2021, 01:24 PM
Farhoof's Avatar
I see.
It's the same reason for me, I just don't want to update unless I absolutely have to and with this card I will be prepared.
  #27
Old 05-04-2021, 01:35 PM
Ok, thanks!
  #28
Old 05-05-2021, 10:44 PM
drums77's Avatar
drums77 drums77 is offline
Currently I’m still using my Mac Pro Mid 2010 with macOS Mojave, HDX, PT Ultimate 2021.3.1 and HD I/O.
Still a solid system.
Mac Pro (Mid 2010) Six Core 3.33GHz macOS 10.14.6 MSI Radeon RX 560
Pro Tools | HDX, HD I/O 16x16, HD I/O 8x8x8
Pro Tools Ultimate 2022.9
MacBook Pro (Mid 2012) i7 2.3GHz macOS 10.15.7
Pro Tools 2021.12
Apogee Duet
  #29
Old 05-06-2021, 03:41 PM
Justin1524 Justin1524 is offline
Still on my maxed out 2010 cheesegrater with an updated vid card for Mojave and an HD Native card. Works like a champ with the latest Pro Tools. I will upgrade to M1x when software works with it. Probably at least 1 year away.
Justin (Proud Pro Tools Ultimate PERPETUAL license owner)
Admin
www.elevenrackpresets.com
Studio: 2021 Mac Studio Ultra M1 20 Core CPU, 48 Core GPU, 64GB Ram, 4TB SSD boot | Pro Tools Ultimate 2022.12 | PreSonus Quantum 4848 interface| MOTU 112D interface | Digi PRE, FR OctoPre MKII, Mackie Onyx 800R, Panasonic WZ-AD96M (x2) and DA7, Eleven Rack, Apogee Big Ben, Mercury, Rode K2, Slate VMS ML-1 (x2). Laptop: Dell Inspiron 5559, i7-6500U 2.6Ghz, 16 GB RAM, 15.6" 1920x1080 1TB SSD
  #30
Old 05-10-2021, 01:31 PM
Pythagor Pythagor is offline
Hi, i just installed Mojave with MSI RX 560 on 5,1 12 core 2,93. Unfortunately i found out that many applications launch approx 1.5 times longer then on HS. More of trouble, after installing 3 HDX cards applications like DigiTest or PT take forever to launch. Anybody have seen this behavior?
Maximizing a Mid 2010 Cheese Grater NoiseRoom macOS 8 09-05-2019 05:51 PM
How is Protools 2018 behaving on the 2010 cheese grater Mac? fourthtunz macOS 12 08-21-2018 08:30 AM
macOS 10.14 Mojave and “cheese grater” Mac Pros jsbach Pro Tools 2018 37 06-17-2018 01:50 AM
Best video card for cheese grater Mac and HDX? johnnyv Pro Tools HDX & HD Native Systems (Mac) 16 05-09-2017 02:42 PM
BEST CDRW to put in new Cheese Grater? Lee Blaske Pro Tools TDM Systems (Mac) 5 09-13-2002 09:05 PM
