Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 04-04-2025, 05:26 PM
ajazzie ajazzie is offline
Default C20 cap track in control 24 damaged.
Found my problem, well more than likely.
The C20 cap on the board has a damaged negative side( fitting ring) on the circuit board.
This undoubtedly is my cause, does anyone know where the negative side of the c20 cap terminates or tracks too on the power supply circuit board? I’ll need to jump the negative side to the same place if possible, realising it’s a multi layer board this is difficult but not impossible.
One Possiblyis it may be the same as the C19 cap track, however without any schematic it’s extremely difficult.
Does anyone have a schematic for this, I know it’s been asked a zillion times.
Even an excerpt for this area would be fantastic.
Regards.
A Gentleman is one who can play the bagpipes, yet chooses not to.
Old 04-06-2025, 05:37 AM
tope d's Avatar
tope d tope d is online now
Default Re: C20 cap track in control 24 damaged.
Hi, you can try and check with some of the authorized repair centers. https://avidtech.my.salesforce-sites...roduct-Repairs
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 05-12-2025, 07:49 PM
Just for an update and potential fix if you need it I received my Control 24 power supply back 2 weeks ago and have it running 10 hr days perfectly now.
The company who fixed it have done several of these boards when Digidesign existed and have compiled a schematic for the board and a database of fixes related to symptoms.
My fader issue turned out to be the solder joints underneath the moles plugs where the faders attach to the power supply, these could not be seen as the cracks were so small and only divided as the board heated up.
This has been somewhat of a pain to solve, they did confirm that the C20 cap would have had no effect on the faders whatsoever. I mentioned it to them as it’s been identified by many as the potential culprit, however they said to me that more than likely unplugging the faders and plugging them back in would probably have fixed the issues and probably manipulated the soldered joints to a favourable connection that may or may not have worked either temporarily or for a while.
Either way , good to go.
Hope this helps someone.
Fast Track Ultra Control Panel Disable Host Control?? blackbird99 FireWire & USB Audio Interfaces (Mac) 1 03-05-2020 03:03 PM
PT LE 8 Media Damaged******** kvstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-17-2012 03:50 AM
Damaged Disks Jeff0008 Pro Tools M-Powered (Mac) 2 10-24-2010 09:51 AM
PT Install DVD Damaged ? markus44uk Pro Tools TDM Systems (Win) 6 03-12-2009 04:26 PM
Damaged PCI Cards Plastik909 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-06-2003 12:45 AM
