I must be nuts.. where is this in the menu? thx..:)
anyone?
I ve searched this DUC and cant find a answer.. has anyone figured this ouit? I downloaded some groove templates but cant find the inport option.. thx..:)
If I understand your question and read the reference manual correctly...
"Use folders and subdirectories to organize DigiGroove templates. However, be sure they are always located in... C:\Program Files\Digidesign\Pro Tools\Grooves (Windows) or... Applications/Digidesign/Pro Tools/Grooves (Macintosh). Groove template files located elsewhere will not be available in either Groove Quantize or Beat Detective. " (Page 363 of the 6.7 Reference Guide) In other words, with the 'Finder' (or PC equivalent), manually placing your downloaded groove templates inside the appropriate folders (see above) should then make them available within your sessions. I hope this helps. If not, my bad - I am misunderstanding you.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
thank-you for taking the time to help.. it worked..:)
You're welcome. I'm glad you're... uh, grooving again (badaboom).
Andre....when you say manually import what exactly do you mean...let me explain...
I make a Groove template using Beat Detective and I save it in the Grooves folder. When I open the Groove drop down menu in Strike, I don't see it. I see all the other grooves that came with Strike but not the created one which is in the same folders as all the others....I am assuming the folder I am looking at is the same one as Strike!! can you help....thanks Mike
Groove Template Workflow | Analog Kid | Tips & Tricks | 1 | 12-20-2013 05:41 PM |
Groove template into Strike | dream5695 | Pro Tools 11 | 6 | 12-13-2013 11:16 PM |
Groove Template Question | Thrusby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-27-2012 09:09 PM |
Groove template as Grid? | DrFord | Pro Tools TDM Systems (Mac) | 5 | 02-23-2010 02:33 PM |
Midi Groove template | hanz marathon | Pro Tools TDM Systems (Mac) | 0 | 02-16-2005 05:05 AM |
