  #31
Old 09-30-2022, 03:21 PM
Eric Lambert's Avatar
Default Re: Kudos to Avid for 2022.9
Originally Posted by MIKEROPHONICS View Post
You can use Source Nexus on a PC and have the same functionality as AUX IO
For $299
  #32
Old 09-30-2022, 03:26 PM
Another great thing I just discovered, so I'm taking my hat off for you again, Avid:
With ProTools Intro now allowing you to use local sessions (albeit quite limited in session size) I'm able to install Intro on an old Intel machine which runs Big Sur. This isn't exciting, except for me it is. I've had an ongoing battle with SSL where older iteritation of several of their plugins would not load on M1 nor Monterey. It meant that I was locked out of hundreds of sessions from our past, and we do often go back in and revise them for clients.
Before PT Intro, there was no way for me to gain access to those SSL settings so that I could recreate them with updated iterations of their plugins. Now I can send a session to the older machine, open the session (8 tracks at a time) and at least get screenshots of those settings. This sounds silly but it was actually a big deal for our company.
Thanks, Avid, for saving the day spoiled by SSL!
  #33
Old 09-30-2022, 03:31 PM
Sardi Sardi is offline
Couldn’t you just install the regular version of Pro Tools on that Intel Mac?
  #34
Old 09-30-2022, 03:37 PM
JFreak JFreak is online now
it is the same install. Version is derived from your license (or lack of it).
  #35
Old 09-30-2022, 03:43 PM
I’m aware of that.
My point is, why does Intro allow them to open old sessions? Why couldn’t they have run regular PT on that machine months ago?
If they don’t want to move iLoks around, fair enough. But if I had sessions that I needed access to, I would have been doing that in a heartbeat.
  #36
Old 09-30-2022, 04:27 PM
thebeatless thebeatless is offline
Originally Posted by Eric Lambert View Post
For $299
I just bought source nexus a couple of weeks ago. Should have gone with the rental option.
  #37
Old 10-01-2022, 11:16 AM
The Weed's Avatar
The Weed The Weed is online now
For those on Mac, have a look at Ginger Audio - whether you have 2022.9 or not. They have told me they are working on a Windows version.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #38
Old 10-01-2022, 04:29 PM
Intro is free whereas the regular version (Ultimate in my case) is not. I'd have to transfer the iLok asset from one machine to the other (or move the iLok dongle, which is tough to access on the older machine), but the worst part is that I wouldn't be able to have both machines running PT simultaneously, and that would make moving parameters tougher.
  #39
Old 10-01-2022, 04:30 PM
I've tried Room but didn't find any purpose from it. Which app are you referring to and how would it be helpful?
  #40
Old 10-01-2022, 04:39 PM
The Weed's Avatar
I thought they explained from their website. It's similar to Source-Nexus, but there's a free version and a paid version that's much less than Source-Nexus. All three are virtual routing solutions. Sorry if it doesn't work for you.
SonoBus
Avid Link says PT 2022.9 is on the way huzzam Pro Tools 77 09-29-2022 06:42 PM
Avid S3 Still A Good Buy Tail End of 2022? Chevron Pro Tools 10 09-19-2022 03:18 PM
2022.7 with Avid Pre protocol ChrisMac Pro Tools 4 08-01-2022 04:31 PM
Pro Tools 2022.6 with Avid Control 2022.4 stargazer Pro Tools 2 07-01-2022 07:32 AM
