Old 10-19-2021, 06:42 PM
Mixedbyjoe Mixedbyjoe is offline
Default HDX TB3 Chassis- Power Cable
Got a used HDX TB3 Desktop chassis, but it doesn't have a power cable for the HDX card. All the photos show the cards loaded without the power cable, but it definitely doesn't work without it. Avid says TCB-HDXB, but that's definitely not the correct one. Seems to be very little info on these boxes here and the web...
A- Did yours come with this cable?
B- Which one do I need?
Specifically, this is for use with my MacBook Pro 16,1 OS 10.15.7 PT 2021.7
Old 10-23-2021, 06:16 PM
mriegler's Avatar
mriegler mriegler is offline
Default Re: HDX TB3 Chassis- Power Cable
Typically a selection (2 or 3) of power cables ship with the HDX card. Sonnet i think has a black 6-pin female cluster in a 2x3 config with a latch, the card has that black female 4x1 config (also as a triple daisy chain to connect up to HDX3). There's some alternatives to connect to PC 4-pin disk drive power etc...
The pix below show the included with HDX card standard power cable and an Avid TB3 rack mount chassis (which is Sonnet). And that works fine. Not sure, where to source them best, saw some overpriced on eBay upon googling "HDX card power cable". Attached the part number sticker from their posting if you want to try to get it from Avid as a spare. Or if anybody on here bought 2 HDX cards, they get 2 cables but in an HDX2 system of course only need one...
Their recommended cable appears to be the result of a change with a particular Sonnet eGFX chassis, so they thought you might need that cable (assuming you had the one that came with the card and not being able to use it).
https://www.pro-tools-expert.com/hom...erbolt-chassis
File Type: jpg Screen Shot 2021-10-23 at 6.30.12 PM.jpg (36.3 KB, 0 views)
Old 10-24-2021, 05:48 AM
Thank you! That’s exactly what I was looking for. I had found that article but it referenced a different chassis so I couldn’t confirm.
Mac OS 10.15.7 Lynx Hilo Pro Tools HDX (Latest)
Old 10-24-2021, 10:32 AM
mriegler's Avatar
BHPhoto seems to have it at MSRP 39.99, but should be able to be sourced through any Avid dealer. No need to go to pricey eBay scalpers...
https://www.bhphotovideo.com/c/produ...YaAjELEALw_wcB
Old 10-24-2021, 10:33 AM
Thanks! Sourcing isn’t the problem, I had no idea WHICH cable I needed-
Magma and SBS 7 Slot Chassis Cable #'s ??? Table Syrup Records Digidesign Hardware & Software 0 09-27-2010 11:56 AM
Magma Chassis Cable (old one) needed syMPh Pro Tools TDM Systems (Mac) 0 11-05-2009 01:43 PM
Digidesign/SBS 7slot exp chassis Cable HELP!! tubejay Digidesign Hardware & Software 10 03-21-2008 12:01 PM
longer cable for expansion chassis? venusmuzik Pro Tools TDM Systems (Mac) 1 03-20-2002 09:05 AM
expansion chassis cable indigo Pro Tools TDM Systems (Mac) 2 12-11-2000 07:05 AM
