Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 03-05-2011, 12:14 PM
bigb11 bigb11 is offline
Question Stereo eq plug in for 2 track audio?
Hey does anyone know of any good stereo eq plugin for 2 track audio? I get sent beats all the time in mp3 format and almost every beat needs and eq boost somewhere whether it be the highs or the lows. I need a stereo eq plugin not a mono...
Old 03-05-2011, 12:50 PM
nst7 nst7 is offline
Default Re: Stereo eq plug in for 2 track audio?
Pretty much every plugin ever made is both mono and stereo. You should be able to just open it up as an insert on the stereo track, the same way you do with a mono track. This includes the free eq's that come with Protools.
Old 03-05-2011, 01:05 PM
HD2 HD2 is offline
By it's very nature the compression in MP3 usually throws out a lot of the highs and lows, So I would be inclined to just re-create the beats or if possible get them to send you a wav file at the resolution it was recorded at.
But as nst7 said you can use any of the EQ plugins that come with Protools or take your pick of the many that are out there.
Old 03-05-2011, 05:09 PM
To make that a bit more clear, the compression is DATA compression, not audio compression(like with a compressor plugin). As said, most any EQ plugin will work fine on a stereo track or file. The stock Digirack EQ III is a fine plugin. Most will be very similar, with the exception of the Pultec, which is a different beast entirely. I can't live without my Pultec
Multi-Mono Trim Plug-In on Stereo Track? Napping Pro Tools 10 1 02-06-2012 09:48 AM
how do you stereo flip an audio track ~Murda Me~ Windows 3 06-14-2011 11:22 AM
On a stereo audio track, the left track is completely dead ckwhy2008 Pro Tools M-Powered (Mac) 1 04-09-2011 05:16 AM
Monitoring thru stereo audio track WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-01-2007 11:50 PM
Mono to stereo plug-ins ... track count? banana boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-31-2002 01:20 AM
