Grey screen crash on loading plugins...
got my PT10 today, got it installed and then when it launches it grey screen crash on scarnning the AIR plugins.
I assume it crash on only a certain plugin, so I move every plugin I have into the unused folder and now it grey screen crashes on loading plugins. any ideas? my comp: OS: Windows 7 64 Bit Enterprise. CPU: Intel® Core™ i7-860 (2.8GHz,8MB) Memory: 6GB (3 X 2GB) Internal Hard Drives: 128GB SSD =OS/Pro Tools/Plug-Ins 500GB= project drive. 003 rack. |
Re: Grey screen crash on loading plugins...
Im having the same exact issue. I haven't even got a chance to experience anything with Pro Tools 10. I just got it today and its crashing upon launching. For a split second I can see that it would crash as soon as an AIR plugin would attempt to load.
So I tried to go to the plugins folder and removed all the AIR plugins (Which sucks). I did this just to see if it would work but no luck. It would freeze on any plugin loading. I even temporarily removed all my 3rd party plugins and that has nothing to do with the crashing issue. My computer is running off of Windows 7 Ultimate 64bit with service pack 1 like Avid recommends. I had ZERO issues with Protools 9 so even though I purchased Protools 10 I have to go back to version 9 because I have sessions to work on with clients tonight. PLEASE ADVISE US FOR ANY NEW TIPS TO FIX THIS ISSUE!!! Audio Interface: Digi002 RACK OS: Windows 7 Ultimate 64 bit Service Pack 1 Processor: Core i7 920 2.67 Memory: 3 X 4GB = 12GB RAM Internal Hard Drives: 500GB (C:) OS/Pro Tools/Plugins 2TB (D:) Protools Session Projects 1TB (E:) Library for sounds and finished songs Sandra Report: ----------------------------------- SiSoftware Sandra Computer Model : OEM System Product Name Workgroup : WORKGROUP Host Name : ABRStudio-PC User : ABR Studio Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.81GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : ASUS P6X58D PREMIUM BIOS : AMI (OEM) 0604 01/21/2010 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 12GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Chipset Model : Intel Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Total Memory : 12GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 536MHz (1.07GHz) Memory Module(s) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.84GHz, 512MB DDR3 2.2GHz 256-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.84GHz, 512MB DDR3 2.2GHz 256-bit, PCIe 2.00 x16) Graphics Processor Compute Shader Processor : NVIDIA GeForce 9800 GTX+ (128SP 1.84GHz, 512MB DDR3 2.2GHz 256-bit) Storage Devices WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, 32MB Cache) : 466GB (C:) WDC WD1001FALS-00E8B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (E:) Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) : 2TB (D:) TSSTcorp CDDVDW SH-S223L (3.9GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 4GB (F:) Logical Storage Devices System Reserved : 100MB (NTFS) Library (E:) : 932GB (NTFS) @ WDC WD1001FALS-00E8B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Protools (D:) : 2TB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) Hard Disk (C:) : 466GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, 32MB Cache) PART 16 (F:) : 4GB (UDF) @ TSSTcorp CDDVDW SH-S223L (3.9GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS 88SE914D SATA-600 Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (Ethernet) Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2 (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9 Respectfully, Alex
Alex "Q-Dash" Medina CEO, ABR Productions LLC Audio Engineer Producer, Writer Last edited by abrstudios; 10-22-2011 at 02:39 PM. Reason: added audio interface |
Alex,
I just updated everything on my win7 too and tried every possible fix I can think off and search off from this forum. updated ilok driver ran the installer as admin updated all hardware driver. finally gave up, reinstalled 9.05 and all my plugins and and PT loads just fine. maybe I'll give it a try again when 10.1 comes out... |
Have any of you tried installing 10 on a freshly formatted partition?
Run as admin during install and during launch of ProTools.exe. Result? |
No not yet. I was not wanting to do this since I install all of my virtual instruments which are HUGE FILES on the same OS drive and it takes for ever to install from scratch. But I am definitely rounding up my discs to prepare for that long method. I am going to back up my C: drive first so I can at least restore it just in case.
Alex "Q-Dash" Medina CEO, ABR Productions LLC Audio Engineer Producer, Writer |
The fresh install advice was primarily meant to help you eliminate any doubts if Pro Tools 10 will run on your computer or not. Just install the barebone PT10. If it runs (most likely) I would start the big task of recreating the DAW from scratch. Good luck, 10 is awesome.
took the plunge and reinstalled my OS.
fresh install of win7 64 with only pro tools 10 installed and it grey screen crashed at the exact same loading plugins message. the error window included the following report: Problem signature: Problem Event Name: APPCRASH Application Name: ProTools.exe Application Version: 10.0.0.821 Application Timestamp: 4e97e697 Fault Module Name: KERNELBASE.dll Fault Module Version: 6.1.7601.17651 Fault Module Timestamp: 4e211319 Exception Code: e06d7363 Exception Offset: 0000b9bc OS Version: 6.1.7601.2.1.0.256.4 Locale ID: 1033 Additional Information 1: 6e24 Additional Information 2: 6e2403394b2e64e6d51bc34bb3774724 Additional Information 3: c0d1 Additional Information 4: c0d1136bdcf66a4b842758dc022a154f Read our privacy statement online: http://go.microsoft.com/fwlink/?link...8&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt |
try reinstalling with DEP turned on, having it off sometimes can cause software to not install properly.
good luck. |
Have you disabled Aero? If so go to services and disable "Desktop Windows Manager". (DWM)
Enable DEP
This troubleshoot can sometimes help resolve issues with installing and launching Pro Tools software. If you have disabled this for any reason, it is often recommended to re-enable it. Open the Start menu and type "cmd" (without the quotations). The Result you get should be "cmd.exe". Right-click on "cmd.exe" and choose "Run as administrator". Click the Allow button if it asks you for permission. Type or copy & paste this into the command prompt window: bcdedit.exe /set {current} nx OptIn Hit enter and you should see the confirmation: Operation Completed Successfully. Restart the computer and DEP should be on for the entire system.
Pro Tools 10.3.8 Crash When Loading Plugins | jahylto | Pro Tools 10 | 5 | 10-10-2014 10:13 AM |
Grey-screen Full crash on loading session - ideas ?? | Ru_C | Pro Tools TDM Systems (Mac) | 4 | 07-29-2011 05:40 AM |
Waves plugins either crash or pop up w. grey whole screen | ozanerk | Pro Tools M-Powered (Win) | 4 | 11-06-2007 06:19 AM |
Grey Screen of Death | hughfunkler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-18-2007 05:16 PM |
Crash (grey screen) on new project. | cupofnestor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-23-2006 11:31 PM |
