Old 03-30-2001, 09:17 PM
Renato Renato is offline
Default Digi 001 with Matrox RT MAC video capturin card on Apple G4
Hey Steven ! How are you ?
Thanks for your reply, I have thinked
about anyone is going to reply this topic.
To complement this discussion, you
work with two monitors? In Pro Tools Le
and Final Cut ? Or General for in the Mac OS and all softs ?
(Using a second monitor port for the RT MAC, shure!)
[This message has been edited by Renato (edited April 17, 2001).]
Old 04-17-2001, 05:33 PM
unsub1 unsub1 is offline
Default Re: Digi 001 with Matrox RT MAC video capturin card on Apple G4
To my surprise, the Digi001 has no conflicts with my RTMac so far. I am running a 400MHz Sawtooth G4 with 448 megs of RAM. I am also running an Adaptec 29160n SCSI card with no problems. Hope this helps.
steven
Old 04-18-2001, 04:39 AM
David Lawler David Lawler is offline
Me too......
G4-466, 384 Ram, Digi001 w/Protools LE 5.1, Final Cut Pro 2.0 w/MatroxRTMac, 29160N SCSI controller, 2 external 9G Seagate LVD drives (for video only)
So far, all is working smoothly.
Old 04-18-2001, 04:45 AM
usinare usinare is offline
i am using fcp 2.0 with rtmac and pro tools le and no problems. i have a g4 450 dual with 512 mb ram. u will need a separate hard drive for video capture and rendering. a 7200rpm internal ide is sufficient.
Old 04-18-2001, 09:46 AM
Renato,
I use the dual monitor setup for everything, audio, video, web (Flash, etc), word processing, etc. The RTMac does occasionally offer me a higher resolution, but other than that, is rock-solid.
steven
Old 04-18-2001, 05:32 PM
Kerry C Kerry C is offline
Little off-topic for this forum, but could anyone give me a quick review of the RT Mac? Does it truly render in "real-time?" And how much? All transitions or only some? Moving text, objects, etc.? Is this all real-time at full res/frame rate also?
Thanks,
kc
Old 04-18-2001, 10:35 PM
The RTMac is a PCI card that acts as both a real-time accelerator and a second video card. Your most popular transition are in real-time (if nothing else, good old cross-disolve), as are your typical motion effects (opacity, scale, position, etc.). It previews in real-time at full framerate and very high quality resolution. It comes with a breakout box that allows you to capture analog, but even better, to connect to your monitor/deck without having to have your camera in the loop. I'm really pleased with it.
steven
Old 04-20-2001, 11:17 AM
Thanks, Steven. I think I may have to make that purchase happen.
Good day.
kc
problem with dual monitor matrox g550 video card toasterd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-25-2003 02:35 PM
problem with dual monitor matrox g550 video card toasterd Pro Tools TDM Systems (Win) 0 09-25-2003 08:48 AM
Dual Monitors:Matrox Millenium II PCI video cards - Second Monitor Card for PCI Mac/W neopotato 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-08-2001 10:10 PM
matrox rtmac dual head video card is out.... thefly Pro Tools TDM Systems (Mac) 1 03-16-2001 08:20 AM
Want a Dual video Card? Send Matrox Request MacDaddy WGAR Pro Tools TDM Systems (Mac) 2 03-09-2000 06:53 PM
