Old 08-09-2016, 01:32 PM
Luigi2000 Luigi2000 is offline
Default Over 32 outputs, is this right way to change I/O?
Since PT has a 32 channel limit, when not using avid hardware, and my spidif exeeds that limit, how do I use it?
I have a raydat pcie card wich has 32ins and outs + spidif.
I want to use my spidif out, so I guess I have to deactivate my last 2 analog outputs? is this right? 30 outs + spidif out(2 channels) = 32 channels
is this correct?
WIN10 Pro Tools 2021
Old 08-09-2016, 02:34 PM
john1192 john1192 is offline
Default Re: Over 32 outputs, is this right way to change I/O?
hi, i think you will have to move your Spdif L&R over to 31/32 for Pro Tools to see it / and you may have to move those ones that are DeActivated in 31/32 ..
cheers john
is this correct?
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 08-09-2016, 11:30 PM
JFreak's Avatar
JFreak JFreak is offline
That is true. PT simply takes first 32 i/o it sees, so there should be some kind of external application to map those i/o the way you want to.
Janne
Old 08-10-2016, 04:11 PM
weezul weezul is offline
mega edit: didn't realise you said OUTPUTS. Sorry
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
11.2.2 change outputs glitch Shifted Music Pro Tools 11 22 01-20-2015 10:04 AM
How to Change Default Outputs?? teacherman Tips & Tricks 2 07-24-2014 03:04 PM
Can I change Audiosuite's default outputs? infiniteloop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-25-2009 11:18 AM
Change the automaticly set outputs Atarie Pro Tools TDM Systems (Mac) 3 01-05-2005 07:39 AM
Change Wavedrivers Outputs ? Eduardo Apolonia Pro Tools TDM Systems (Win) 0 05-27-2000 12:53 PM
