Old 01-05-2005, 04:51 AM
Atarie Atarie is offline
Default Change the automaticly set outputs
By circumstance my monitors are connected via the C|24 to output 7/8 of my DIGI192 interface. If a make a new track in my project Protools automaticly sets the output on 1/2. Is there a way to change this to 7/8?
Come on you waffle makers, this one is for Jean Claude van Damme!
Old 01-05-2005, 05:50 AM
Vaphoron Vaphoron is offline
Default Re: Change the automaticly set outputs
Go to the I/O Setup window and change the "Default Output" in the bottom left to analog 7/8.
- Jason
Andre Knecht Andre Knecht is offline
Default Output Path
You can specify the default Output path assignment for new tracks, in each available format.
To specify a default Output in the I/O Setup window:
• Select a format and Output path from the Default Output Selector.
(From Page 81 of the PT 6.7 Reference manual)
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 01-05-2005, 07:39 AM
Thank you! I'll try this.
Why does the output to amp selector change the main outputs? Hotcrazyfruit Eleven Rack 3 02-22-2011 07:06 PM
plz help need 2 change digtial outputs in pro tools 9 le shamanrock Pro Tools 9 6 11-18-2010 02:31 AM
Can I change Audiosuite's default outputs? infiniteloop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-25-2009 11:18 AM
Masssive squeek ouch noise when i change outputs eastcote Pro Tools TDM Systems (Mac) 5 12-14-2005 09:11 PM
Change Wavedrivers Outputs ? Eduardo Apolonia Pro Tools TDM Systems (Win) 0 05-27-2000 12:53 PM
