Old 01-02-2012, 07:39 PM
CassidyGT CassidyGT is offline
Default DINR LE in Audio Suite but not in plug in list
DINR is showing up in the audio suite list, but it does not show up when I try to insert on a track. I have reinstalled a couple of times. Any ideas?
Old 01-02-2012, 07:42 PM
Top Jimmy's Avatar
Default Re: DINR LE in Audio Suite but not in plug in list
DINR LE is an Audiosuite only plugin. There is no RTAS version. The only version of DINR that can run as an insert plugin is DINR TDM.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 01-02-2012, 07:44 PM
SO no way to use it in Pro Tools Native?
Old 01-02-2012, 07:59 PM
Top Jimmy's Avatar
Not TDM, but you can certainly use LE. You just have to be satisfied in using it in a non real-time fashion.
James Cadwallader
Old 01-02-2012, 08:01 PM
hmm - OK. Not sure how to do that. Do you know if there is a user manual somewhere?
Thanks!
Old 01-02-2012, 08:24 PM
Top Jimmy's Avatar
The should be a plugins guide installed in your Pro Tools documentation folder. DINR is also referred to as BNR. You highlight a section of just the noise in your track and click the learn button in the plugin to create a noise profile. Then you use the fit or super fit functions to create a noise reduction contour. I found that the super fit function always seemed to work better than the fit function and I always jacked the whole contour line up a few dB.
Be forewarned, DINR is a dinosaur and does not fare well when compared to something like RX. I haven't used it in a while but I did for a few years when doing a lot of commercial spots. DINR works most transparently when you're only trying to reduce a slight noise floor. Anything more than that and you quickly start getting into artifacting. It often takes quite a bit if experimenting before you'll manage to stumble upon the best that DINR can give you. Play with the response, release and smoothing to find what works best with your current material.
James Cadwallader
Audio Suite to Plugins List? Kon Alexiou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-27-2010 01:54 PM
Mbox 2 mini - no vi's in audio-suite list jf1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-29-2008 05:01 PM
Audio Suite list messstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-10-2005 11:00 AM
Audio Suite List kerrycrafton Pro Tools TDM Systems (Mac) 3 05-19-2004 10:51 AM
audio suite plug-ins slinky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-25-2000 07:43 PM
