Old 06-09-2011, 08:19 AM
Obe1 Obe1 is offline
Default Hardware Inserts on PT 9
Well the answer is prob the same for most versions of PT, but I've never used hardware processors before and am having some trouble.
I'm using a Focusrite Saffire interface with PT 9, and am trying to figure out how to configure hardware inserts. I think I've got most everything set up right, my question is, let's say I have a single channel compressor plugged into analog output 3, and back into analog input three (as the PT manual says to do), is it necessary for the I/O inert page in PT to be setup as mono, or can it be set up as stereo although channel 4 of the 3-4 isn't being used?
Theoretically you would think that even if it's set up as stereo that you would still get some kind of signal coming back into PT even though you're only using channel 3 (instead of 3 and 4 of the stereo pair of I/O's). But it doesn't. One might ask, "Why don't you just go into PT and set it as mono then and test it for yourself?" Well, I'm at work right now and impatient lol IF you're bored, humor me with some input! Thanks.
Chris
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
Hardware Inserts trackone Pro Tools TDM Systems (Mac) 6 01-27-2012 06:22 AM
Hardware Inserts in LE??? plex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-26-2007 11:56 AM
Hardware Inserts CosmicJunkie Pro Tools TDM Systems (Mac) 1 11-20-2007 03:12 AM
002 Hardware Inserts tele_player 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2003 11:02 AM
