Latency problem (couldn't find the fix on DUC)
I know LATENCY is among the most talked-about issue on this forum. I’ve spent days searching, but still have not found the solution to my problem described below. Any help would be appreciated!
The problem Newly recorded audio regions are being written with a noticeable latency. Pro Tools is placing the newly recorded audio region in the right spot (i.e., the start point of the new audio region is exactly where I start recording or punched in). There is no latency effect while recording (I use low latency mode). However, during playback, the underlying audio of the newly recorded track is noticeably later than the other previously recorded tracks. This happens whether I record in low latency mode, when all plug-ins on all tracks (including master fader) are bypassed and/or listening through the 002R or C/24 headphone monitors while recording. My system - Pro Tools LE 6.4 (002 R) - Mac PowerPC G4 (dual 1.42 Ghz processors; Mac OSX 10.3.8 Panther) - Control 24 control surface - Waves Diamond Bundle 5.0 Recording set up - Always record in low latency mode - Monitoring 8-10 pre-recorded tracks while recording - No internal buses being used - Using the C/24 Focusrite mic pre’s while recording - Same latency effect happens regardless of use of outboard effects (e.g., 1176, Vipre pre) - Same latency effect happens regardless of different H/W buffer size settings (mainly use 1024; 512 or less triggers an ~6086 error, even with all plug-ins bypassed) Thanks for any help you can provide! Dr. Fred |
Re: Latency problem (couldn't find the fix on DUC)
sorry if this is a bit obvious - but you say that all plugins on all tracks are bypassed, have you tried inactivating them or removing them?
Does this happen if you just start a clean session and record one track? |
Like oliarnalds said. The likely culprit is the plugins on the master fader. Bypassing plugins does not eliminate plugin delay, only making them inactive does. You're playing in time with the late audio and finding your tracks to be late when Pro Tools spots the audio to the right place after the recording pass.
Thx for the feedback guys. I didn't realize a bypassed plug-in can still create latency issues. I'll clear the plug-ins off the master fader tonight for a test drive. Now that I think of it, this latency issue started when I began recording from some templates I created with certain master fader plug-ins I've grown to like. When I first started using PT years ago (w few plug-ins) I never experienced the latency issues I have now.
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
Thank again, Top Jimmy and oliarnalds! It was plug-ins on the master fader (even when bypassed) causing the latency effect.
On to the next problem...
Dr. Fred http://www.myspace.com/pitsband PT LE 6.4; 002R (400 f/w; unit software ver 1); Control 24 (refurb) Mac G4 (dual 1.42 Ghz processors; 2 Gb DDR RAM; OSX 10.3.8; storage: (1) 120 Gb internal HD for OSX and programs, and (2) 160 Gb Western Digital ATA/100 internal HD for PT sessions, capturing audio, etc.) Main plug-ins: Waves Diamond 5.0; Antares Auto-Tune 4 Ver 1.0; Drumagog (Pro) Favorite gear: VIPRE preamp; two 1176's; Line 6 POD XT Pro |
You know, you can track with those plugins active if you want. You just have to add a manual compensation step to your workflow and life can move forward. Switch the mixer displays to view plugin delay. If the master fader has 2048 samples of delay on it, then shift the newly recorded track 2048 samples earlier and it will line up.
"Control-Apple" clicking a plugin will make it inactive but keep it's settings. You don't have to remove it.
Remember that in low-latency mode, the audio inputs being recorded are routed back out at the interface for monitoring purposes before going through Pro Tools. Technically, this is why there can be no RTAS processing on a track being recorded. So audio that gets recorded in time with what he hears through a master fader with plugins with delay will be late on playback and can be compensated for by shifting it earlier in time. But I sure wouldn't want to work this way if I had to record a track with lots of punches.
Still can't find "Low Latency Monitoring" in my menu options... | finalcut | Pro Tools 10 | 13 | 02-20-2013 11:52 AM |
where is low latency monitoring on pt 7.1? can't find it... | dbbtexpress | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-26-2007 05:22 PM |
Best way to find out Plugin Latency | vieris | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-07-2005 05:34 PM |
How do I find exact latency? | Last Legend | Pro Tools TDM Systems (Mac) | 1 | 12-08-2002 07:15 PM |
I can't find Low Latency Monitoring. | Blazorge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-29-2002 08:54 PM |
