AES for hardware inserts?
Just wondering if it is possible to use the AES I/O for hardware inserts. This would make it possible to actually use 16ch. of hardware units. Anyone doing this? I am trying to get out of having to buy (2) 192's for 16 channels of hardware inserts.
Re: AES for hardware inserts?
Yes, AES/EBU works fine for inserts. Obviously, if you were using only one 192, the first two channels would need to be used for your system i/o.
Lee Blaske |
Thanks for the info. However what kind of cable would it need to be to hook up analog effects (comp's/EQ's) to a digital AES I/O? I don't know of any AES/DB25 to 8 XLR-M/8 XLR-F any ideas? |
AES/EBU outputs (and inputs) can only be connected to other AES/EBU inputs (and outputs).
The AES/EBU signal contains digital information that needs to go through a digital to analog converter (or A/D) to become analog audio which can be heard, or routed to (or from) an analog device. If you could get an analog signal out of the AES/EBU output, you wouldn't NEED a converter. |
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
Hardware Inserts | trackone | Pro Tools TDM Systems (Mac) | 6 | 01-27-2012 06:22 AM |
Hardware Inserts on PT 9 | Obe1 | Windows | 0 | 06-09-2011 08:19 AM |
Hardware Inserts | CosmicJunkie | Pro Tools TDM Systems (Mac) | 1 | 11-20-2007 03:12 AM |
002 Hardware Inserts | tele_player | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-26-2003 11:02 AM |
