Old 04-29-2004, 01:02 AM
PhilBuckle PhilBuckle is offline
Default Sound Replacer-Stereo?
I just bought Sound Replacer for my HD Accel system (yes I wish Drumagog was available for PT) and I can't get it to print stereo files.
The version is 1.7 and the addendum manual states that to print a stereo file in Sound Replacer just select the .L side of a stereo split file and all should be well. The source track is a mono kick drum. The replacement sample is a split L+R file. Stereo is selected in the plug. I choose the .L side of the file. Damned if I can get it to work. I select a stereo audio track as the destination and SR just prints the one side of the stereo file. Both sides of the file DO reside in the same directory and I've tried WAV and SD11 formats.
I even exported the file out of PTools to make sure there was no voodoo with the sample rate or bit depth. I exported as multiple mono.
I noticed that the resultant file was named Kick.L.SD2. I thought this might be the problem so I tried removing the SD2. That didn't work either. Got me stumped...........and 4 hundred bucks out of pocket.
Any suggestions?
Phil Buckle
HD Accel 2
G4 DP 867
PTools 6.2.3
Panther 10.3.3
1.5 gig RAM
G5 Dual 2.7 OS 10.5.6 HD Accel 2 192+96 I/O
http://philbuckle.com/
Old 04-29-2004, 01:52 AM
Wolfgang Eller Wolfgang Eller is offline
Default Re: Sound Replacer-Stereo?
A little trick that works for me:
If your original track which you want to sound replace is mono create a new empty track underneath the original track and mark it also (SR is thinking the original track is stereo and will produce a stereo track).
Hope it works for you too.
Cheers Wolfgang
www.srs-mastering.de
Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface.
Old 04-29-2004, 03:20 AM
Thanks for the tip Wolfgang. I'll try it tonight.
Sound Replacer Stereo Mode?? Jim Morris Tips & Tricks 6 10-24-2011 09:51 AM
Trigger a stereo sample from a mono channel w/sound replacer bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2007 09:38 AM
Is there a drum replacer/sound replacer??? sethbrand General Discussion 2 03-08-2006 08:40 AM
my sound replacer makes the samples sound higher joeldavidlauver Pro Tools TDM Systems (Mac) 2 05-24-2005 07:59 AM
Sound Replacer Alters Sound of Sample. vze24x2x Pro Tools TDM Systems (Mac) 0 10-25-2003 07:10 PM
