ProTools 8 LE question
Hi all,
just have a question about the CPU (Rtas) usage.. when going on Setup>Playback Engine and choosing 4 Processors instead 2 Processors, on the "System Usage" window the CPU Rtas usage is doubling... is that normal and why? i've a Intel Core2 QuadCore Q9550 @2,83GHz built on Asus P5QL PRO and 4 GB ram Corsair @1066MHz (2x2Gb) Thanks in advance |
Re: ProTools 8 LE question
OK, just to summarize: You have a Quadcore 2,83 GHz CPU accompanied by 4 GBs of 1066 MHz RAM. So why do you care about the RTAS usage meter...?
I have a similar system, on the big session I currently have up;
2 processors= 60% 3 processors= 49% 4 processors= 39% I typically run 3.
i currently set up the buffer on 128 for the tracking... another question... what kind of operating system do you use :)? Xp or Vista?
More XP users than Vista. Vista nets you less power at this point. Hopefully Win7 will make it better.
XP
Hi Tom Why would you not use 4 procs? Nice studio by the way,is that a pair of ns 10's I see very hard to get now a days? Ive sent you a recorded sample of a single via your site contact for your opinion which would be appreciated. seamus |
hmmm TOM@METRO, what kind of audio card are you using? and have you ever got problems with Protools 8 LE? i tried also Waves plugin on it and got crashes @start...
The high cpu usage is a know issue with PT 8. According to Digi Support, it has something to do with "blitting" (how the windows are drawn) that is causing the issue. Digi says they're working on a fix but it's "rather invasive" and is taking some time to correct and test. If, because you've got a quad core and plenty of ram, it's not affecting your productivity, wait for a fix and continue on. If it is affecting productivity (like it did me) go back to 7.4 until they have a solid fix for PT 8. It's already been close to 3 mos. since the issue was identified and a solid fix isn't in sight yet. Try a search in the DUC for high cpu usage. You'll come up with a lot of threads since PT 8 was released.
Oh thank you so much,my last question is this:
Is it a normal bug on protools le 8 to have got the cpu usage lower when i use 1 processor and higher when i use 4 processors? talkin about 15% higher with 4 processors. Anyone 's got this problem with digi002? |
Protools HD2 question | Mr.SCS | Pro Tools TDM Systems (Mac) | 7 | 08-25-2013 10:25 AM |
protools 9 HD question...PLEASE HELP!!! | bicasso | macOS | 4 | 03-20-2012 05:17 PM |
Protools 8.03 Question... | GordoBot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2010 09:25 AM |
PROTOOLS LE 5.3.1 QUESTION | NewYorkSound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-21-2003 06:28 PM |
Protools Question! | Lukas79 | Tips & Tricks | 21 | 07-23-2002 11:19 PM |
