Old 04-13-2022, 02:27 PM
fork-media fork-media is offline
Default weird graphics glitch with Monterey
weird glitch here - and it makes it feel like the cursor is ofsett. going to fade a clip and it actually affects the clip above!!
trashing prefs sometimes gets rid of it. but how many times a day should that be necessary?
any one else seen this? ( check signature for machine etc )
https://www.dropbox.com/s/4vtjtg7fj1...phics.mov?dl=0
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
Old 04-14-2022, 03:17 AM
thin ice thin ice is offline
Default Re: weird graphics glitch with Monterey
I have never experienced this personally. Did you make a fresh install of 2021.12 on Monterey?
The only glitch I get is when importing a track from another session. It arrives greyed out and cannot be accessed. Then I have to expand the size of the mixer window to big faders and back again to make it work.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3
Old 04-14-2022, 10:16 AM
_JJ_ _JJ_ is offline
When I am in that muti-tool mode, hovering over the bottom right (for example) corner of a clip or edit will bring up the "crossfade" tool while hovering over the top right will bring up the "fade" tool. If you're only trying to add a fade-out then the upper right corner is the spot. Upper left for fade-in. Here's a short vid:
https://www.dropbox.com/s/4yhdhzesmb3eznt/2.mov?dl=0
Although on your example there seems to be no waveform before the clip so it's hard to explain why "crossfade" is appearing ... your cursor is showing the crossfade tool so it thinks you are working on the track above.
Maybe try expanding the tracks vertically to Large and see if those tools make more sense?
Old 04-15-2022, 07:44 AM
DerrickC DerrickC is offline
Have your tried upgrading to macOS 12.3 to see if it fixes the problem? 2021.12 is officially supported by macOS 12.3. I am running this combination and it seems to be fine.
Old 05-08-2022, 02:44 PM
12.3 hasnt fixed it
and track height doesnt appear to make any difference either
not sure I'm brave enought for 22.4 at the min.
anyone else had a go?
cheers
2021.3 graphics glitch? swethington Pro Tools 41 11-18-2022 04:09 AM
Graphics glitch every 60 seconds in 12.5 [SOLVED] DJ Hellfire Pro Tools 12 5 03-29-2018 01:29 PM
Graphics glitch in 12.8.2!! Cryos Pro Tools 12 3 12-12-2017 11:51 PM
Anybody sees this graphics glitch? Meads Pro Tools 12 12 09-03-2015 10:46 AM
PT8 - Pan Window Graphics Glitch JamesH Pro Tools TDM Systems (Mac) 0 08-19-2009 10:04 AM
