Re: Why buy a BM Intensity Pro?
Are you in PT11 or 10? Did you measure synchronisation?
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
I'm in 10... I didn't not, but what's the best way to do that? I still have the card...
hire, borrow or buy a syncheck device
once you have seen how good mojo sync is with avid media and how poor and rubbery (constantly varying even with one playback pass) quicktime sync is you will always want a minimum of a genlocked solution. I did a quick test in PT11 with a BM studio card (but non genlocked) and that faired rather well, which portents to good performance of the media composer engine. cheers
Ah, gotcha... I'll let you know!
#16
there is no such thing as perfect lock with quicktime Tom - that is the whole point. It is inherently unstable and is like building a castle made of sand. Put MXF media into a mojo and run it with a sync io and it is ROCK SOLID.
The same file as a DV pal QT is all over the shop and never the same. It is varying in a dynamic way even before you hit stop and is very variable due to the quicktime engine. We Pal snob types laugh at NTSC being "never the same colour twice" but QT is really "never the same sync twice" in PT. I could forgive it if it was just that the start that was anywhere within the frame boundary from play to play, but to meander al over the place whilst in play? not for me thanks. NO! The BM cards play much better than the mojo with QT (which can't be hard!), but the QT integration with PT 10 is just poor and flawed. Genlocked or not. PT 11 however would appear to be different kettle of fish - I know as I have I have done the tests and the BM decklinck studio (un genlocked as I didn't have a sync HD) played very accurately within PT with avid MXF HD media. Buy rent or borrow a syncheck and do the tests and you will be shocked! cheers
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com Last edited by MIKEROPHONICS; 07-23-2013 at 08:23 AM. Reason: grammar |
#17
http://avid.force.com/pkb/articles/e...nts&popup=true
Sonny Keyes Toronto http://www.sonnykeyes.ca Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20 Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10 |
#18
#19
There were all sorts of issues that required beam-sync to be disabled too. The same can't be said for other QuickTime based applications. People playout to tape from FCP all the time with no sync issues and QuickTime plays nicely in other DAWs too, so QuickTime itself isn't flawed. |
#20
Other applications are doing different things I.e apples & oranges. FCP plays a movie from a known frame start and audio at the same time from the same position. PT is doing something different and playing sample accurate audio but trying to lock video to that. I cannot comment on other daws as I only know the AMS Audiofile as well as Pro Tools.
Whether QT is flawed or not,if you want reliable sync that isn't slewing around (to use synchroniser speak) then mxf and avid mojo in PT are your sensible option. I will see if I have a video so I can show you how sloppy it really is.
Pt9.6 and intensity pro | sven larsen | macOS | 0 | 08-28-2012 04:27 AM |
BM Intensity Pro support, when? | olamo | Windows | 4 | 08-09-2011 11:15 AM |
Intensity Pro | EarHole | Post - Surround - Video | 16 | 04-28-2011 08:49 AM |
Intensity for sale | mikevarela | Post - Surround - Video | 0 | 04-22-2010 05:05 PM |
Blackmagic Intensity | mikevarela | Post - Surround - Video | 7 | 04-21-2010 04:37 PM |
