Old 08-04-2004, 08:26 AM
graveleye's Avatar
graveleye graveleye is offline
Default Back-up Power Supply
Due to some road construction near my home, I am experiencing a rash of 1 second-long power outages.... just enough screw up the computers. I lost one because of a sudden power loss last week and had to rebuild it. Luckily, it wasnt my main PT machine, and by the time I power it up in the evening, they are done working. But if I was working during the day, it would be a nightmare.
I'm curious about these back-up power supplies though. Can having one of these prevent these small interuptions in power? Any suggestions as to what I should look for that would be safe with my gear?
Thanks in advance for your ideas.
Kev
GIGABYTE X58A-UD3R, INTEL CORE i7 960, NVIDIA GEFORCE 8400GS, WIN 7, MOTU 896mk3 HYBRID, PT 10.3.2
Old 08-04-2004, 08:54 AM
Keith Owens Keith Owens is offline
Default Re: Back-up Power Supply
Kev, yeah get you a backup pwr supply asap. When the pwr goes out they kik on immediately with a low volume ring to let you know it's on battery backup.
soon to be back at it again...
Old 08-04-2004, 08:57 AM
graveleye's Avatar
cool - just to make sure, can it kick on and off that quickly?
Old 08-04-2004, 09:04 AM
Bastiaan Bastiaan is offline
Those boxes are made to give you time to properly power down your PC. Usually they are able to power your PC for 20 ~ 30 minutes or so on their own. I bet the time decreases when you als connect your video-monitors to it, but if its one sec....should work.
Usually these UPS's (uninteruptable power supply) come with a serial or usb cable to connect to your PC, and on your PC you can then install a little program that gives the proper powerdown command when power is cut. With your multiple little poweroutages you dont want that...so make sure you set it it up so it wont go down....
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 08-04-2004, 09:11 AM
lemix's Avatar
lemix lemix is offline
That is terrible, and so sorry to hear, GE.
Yep..UPS should tie you over
Just hoping the B&G won't be effected...we cannot afford the fridge to malfunction !!
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 08-04-2004, 01:33 PM
where02190 where02190 is offline
A good UPS is worth it's weight in godl, and a must have for any studio. You can get a decent one for around $500 that will give you several minutes of run time, more than enough to save and shut down, or tide you voer during a quick outage.
Old 08-04-2004, 01:36 PM
If you're using the UPS for audio equipment.. make sure you get one with a true sine wave output.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 08-07-2004, 09:03 AM
FWIW, my $120 APC unit just saved the day as I was bouncing to disk and lost all power. The system finished its job like nothing happened and gave me plenty of time to save, close and shut down. And I have the computer, 2 monitors, Digi002, and Focusrite ISA428 all on it. As I am never far away from the system when its working, I figured 5-10 minutes would be fine. So far so good.
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
New Power Supply? musicman476 VENUE Live Sound Systems 1 04-19-2006 08:39 PM
002 power supply/bad power harness? please help :( djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 08:04 PM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
BAD POWER HARNESS/POWER SUPPLY!!??HELP!! snuffacation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-11-2004 03:03 PM
