Help - odd error message
I use the key stroke command set "shift-command-b" to open the export dialog. Today I've done something that creates an "Remove clips from Session..." message. I've pasted the image below.
Anyone have any ideas what I've inadvertently changed? Thanks Jeff |
Re: Help - odd error message
That is the correct response for "Shift+Command+B" as it is the "Clear" command for clips selected in the Clip list.
"Option+Command+B" is the Bounce to Disk command. "Shift+Command+K" is the Export Clips as Files command which will probably open the dialog you're used to. |
You're absolutely correct. I'm having one of those days...
Thanks! |
Pro Tools 11 activation error-licensing service not running error message | Seismic Sound | Windows | 5 | 03-23-2015 05:35 AM |
error message DAE error-6006 | tad3219 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-03-2011 07:17 PM |
error message during installation error 2147213312 | pianovasano | Pro Tools M-Powered (Win) | 1 | 08-31-2010 07:52 AM |
Does anyone know what this error message means. ERROR DAE 9060 | boabyd23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-18-2009 11:41 AM |
A Message But Not An Error Message | RichrdC | Pro Tools M-Powered (Win) | 3 | 01-27-2008 06:57 PM |
