Dies anyone Know?
Regards Clemens |
Soon ...
something maybe for AES in October but probably NAMM in January
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements Thank you, Craig |
See the announcement we made today...
I think the question is when it will be coming in 64bit....
Q: Is Pro Tools 8.0.3 a 64 bit application?
A: Pro Tools 8.0.3 is a 32 bit application. We are investigating 64 bit support and have no release plans to share at this time. ![]() |
![]() can we have a little linkiepoo?
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
I found this linked from the front page of digidesign.com
Pro Tools Prerelease Now Available for Mac OS X Snow Leopard http://digidesign.com/index.cfm?navi...0&itemid=38671
If you don't have it backed up, do you really have it? [ Mac Pro 4x2.66 | 3x23" | 5GB | 4x500GB int. - 4x500GB ext. | 10.5.5 | PT8 003R | Command|8 | BM-5A's ] [ Macbook Pro 2.16 | 17" | 2GB | 1x120GB int. - 2x250GB ext. | 10.5.5/XPproSP2 | PT8 Mbox2Micro ] |
Tim vdB Avid Audio "There's a fine line between stupid and clever." |
32bit kernel can run 64bit apps just fine, it's not that only 64bit kernel suddenly opens the possibility of running 64bit apps. We have had that possibility for ages!
Sure, it's confusing for most people. But it was just as confusing in 16/32 bit transition. Here's a brief history of OSX and its bitness: 10.4: 64 bit CLI apps (POSIX and math libraries) 10.5: 64 bit GUI apps, no restrictions 10.6: 64 bit kernel What this means we've been able to run 64 bit command line tools since Tiger, and we got unrestricted 64 bit apps with Leopard. Sadly, there were not many of them. And now we finally got 64 bit kernel with Snow Leopard, which only means that kernel is not restricted to 4GB memory and 32 bit registers (which is huge improvement on Intel machines, on par with PPC now). It also means that *ALL* kernel extensions (drivers) will have to be 64 bit if you run that 64 bit kernel. If you have even one 32 bit kext, you won't be able to run 64 bit kernel. This is why Apple have defaulted to 32 bit kernel. Otherwise it would not be a problem, but there's plenty of work in progress regarding kexts; even Apple still does not have a 64 bit iPhone driver available!! I can imagine 3rd parties have their hands full of driver development right now. So... This newly pre-released 8.0.3 is "Snow Leopard compatible" but it's still the same 32 bit app we've become used to. I think it will be more than a point release when Digi has the 64 bit Protools ready. I'm betting it will be called PT9, because that is a major new feature. (OSX --> PT6, multi-core --> PT7, GUI refresh --> PT8 and it would suit perfectly if 64 bits would mean PT9).
Waves V8 Comming! | K.I. | Pro Tools 9 | 6 | 01-25-2011 05:56 PM |
Is Digidesign comming out with a New Command 8?? | JGBalzac | ProControl, Control|24, Command|8 | 17 | 10-20-2010 02:25 AM |
No sound comming out of MBOX | toddw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-16-2005 06:03 PM |
Amp Farm 3.0 Comming!! | K.I. | Pro Tools TDM Systems (Mac) | 3 | 02-17-2005 02:34 PM |
Dashboard is comming (again) | pindebraende | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-02-2001 03:41 AM |
