New Mbox User having Problems
I recently bought an MBOX and have had very little time to experiment as of late but when I have, ive had some problems. Mainly, when i record something and have the input volume all the way up through my headphones, the quality is nice and clear. But when i play it back in ProTools through the MBOX and turn the mix to full playback, i get a really nasty fuzz noise over the track. Its not like an amp noise issue because it has happened when i record direct with a keyboard. Again, it sounds fine as im recording when the mix is all the way to input. Its only in playback that i get this problem. Its sorta frustrating because i thought i would at least be able to record ideas easily when i first got it, i knew it would take lots of time for anything fancy, but this is sort of a road block right now. Thanks!
vay |
Re: New Mbox User having Problems
Well I'm not really sure what the problem is as your description is very vague. What exactly do you mean when you say the input is turned all the way up in your headphones? Is it possible you are just overloading the channel input? Honestly there could be a number of reasons for this so I am just starting with the simplest first. Also if you post your system it would be much easier for people on this forum to help you out being there are so many issues with different operating systems, configs.updates, ect... Wish I could help more.
"All paid jobs absorb and degrade the mind." |
I get this too (or something similar)
I find I get air on my tracks. It seems not to be just a headphone output problem, as the more tracks that are recorded to and played back; the louder the air. It kinda bugs me too. not sure what it would be apart from typical air you would get on yoru pc soundcard (which i wouldnt think would be the case, and the noise on my pc soundcard is why i got my mbox). Arch |
MBox Pro, PT 10 New User - Problems | BDJ1229 | FireWire & USB Audio Interfaces (Mac) | 0 | 07-14-2013 03:24 PM |
New user problems | WolfyGK | Pro Tools M-Powered (Win) | 2 | 10-06-2010 07:22 AM |
MBOX Noise Blasts-user warning? mbox recall? | doubtful guest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-03-2007 01:47 AM |
NEW MBOX LE USER HAVING PROBLEMS | NeXuS LE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-07-2004 08:19 AM |
New MBox user-upgraded from AMIII-having problems | Release | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-19-2004 02:03 PM |
