Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 10-27-2021, 11:29 PM
Rym Rym is offline
Default Protools HDX with I9 Build
i want to swap my system from MacOs to Win. Now i need a little advice to buy the right stuff.
I thought about:
- Mainboard 299x or Z590 with thunderbolt
- I9 Intel 10900K or 11900k
- 32 GB Ram
- M2. 2TB Drive
- GT 1030 Graphic
- Win 10 Pro
what would you recomend ?
Thx for your Help
Old 10-28-2021, 07:14 AM
EGS's Avatar
EGS EGS is offline
Default Re: Protools HDX with I9 Build
You should be golden! 10th or 11th Gen i7 or i9 builds are stable & crazy powerful. Mine (see sig) is solid. Windows 10 will run the last several versions of Pro Tools just fine. I'd use Windows 11 on a new build, though; you'll likely get there eventually anyway. Seems like 11 works with apps & drivers written for 10 - no drama. Check out the last few pages here for more build info & tips: https://duc.avid.com/showthread.php?t=238426 Now, if you want bleeding edge (might as well, right?) see this: https://duc.avid.com/showthread.php?t=417530 Note that AMD makes some great processors too; I just have no personal experience with them.
Desktop: PT 2020.5 / Win11 / Intel 11th Gen i9 5.1GHz / 64Gb DDR4-3600 / Gigabyte Z590 Vision D / Focusrite LS56
Laptop: PT 2020.5 / Win10 / older HP ProBook with i7 quad / U-PHORIA UMC1820
Legacy (works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for audio/video demo
Old 10-28-2021, 10:35 PM
Rym Rym is offline
Great thx a lot. But will it run with hdx?
Best
Stefan
Old 10-29-2021, 02:28 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is online now
Yes it should run HDX just fine. I have a 10th Gen. i9 10850K with a Gigabyte Z490 Vision D mobo and all is well. When building your system make sure you install Windows and get it running first before you install your HDX card (UAD2). If your using the internal graphics card you should be able to get the BOIS to post (viewable) immediately. When using a GPU card I had to re-seat it a few times before the BOIS would post (I can tell someone what I did if they run into any problems). You need to use a GPU card cause several plugins I use would not open (UI wasn't visible) when I used the internal graphics card so I had to use my GPU (You may or may not run into this problem). The HDX card for my build had to go in the 2nd PCIe slot or it wouldn't work if I remember correctly. I forget what slot my UAD2 card is in. I have my M.2 drive in the first M.2 slot so it's running off my CPU and not taking any of my six SATA lanes. All my UBS3 and USB2 ports are working fine. I'm not using the Thunderbolt 3 ports but I hear they work fine. Once you get everything running smoothly, please clone your system drive with Acronis or Macrium Reflect, Please do this ASAP. This will save you alot of frustration if your system starts acting funny or an Windows update breaks something. You can thank me later.
What is more relaxing than Music?
Pro Tools Carbon is here!
My HDX is on the way out
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 10.15.7 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2022.4 Ultimate - 16x16 - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (2)
Universal Audio UAD2 Pci-E and Satellite USB Octo v.9.15.1 - SOLO 610 - Twin-finity
Antelope Trinity - 10M
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2 Bomber ADC
Dangerous 2Bus
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Old 10-29-2021, 07:34 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by abc1mce2 View Post
Yes it should run HDX just fine. I have a 10th Gen. i9 10850K with a Gigabyte Z490 Vision D mobo and all is well...
Great!
Old 10-29-2021, 10:12 AM
Rym Rym is offline
Great thx a lot!!
Old 01-17-2022, 03:30 PM
abc1mce2's Avatar
Just an update on my system build. I recently decided to Hackingtosh my mobo to accommodate my PT Carbon purchase (With the blessing of moderator SOUTHSIDEMUSIC). I had no hiccups in the process and very few workarounds for total mobo functionality. One of the 2 ethernet ports doesn't work, (2.5Gigabyte ethernet port) I'm using wifi for internet access, and one of my Pci-e slots acts funky when populated. Other than that I'm a happy camper. MacOS 10.15.7 and PT are working beautifully as a unit and Carbon sounds fantastic. This mobo is golden no matter which OS you decide to use.
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2 Bomber ADC
Dangerous 2Bus
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Old 01-18-2022, 07:14 AM
Just an update on my system build. I recently decided to Hackingtosh my mobo to accommodate my PT Carbon purchase (With the blessing of moderator SOUTHSIDEMUSIC). I had no hiccups in the process and very few workarounds for total mobo functionality. One of the 2 ethernet ports doesn't work, (10Gigabyte ethernet port) I'm using wifi for internet access, and one of my Pci-e slots acts funky when populated. Other than that I'm a happy camper. MacOS 10.15.7 and PT are working beautifully as a unit and Carbon sounds fantastic. This mobo is golden no matter which OS you decide to use.
I'm sure this post (and probably some more details) would be appreciated in the Carbon forum, as a couple of people were trying to get Hackintoshes going for that.
Dominic
Old 02-23-2022, 08:13 PM
RackAddict RackAddict is offline
Is there any particular reason why i9 is aimed for as opposed to xeon processors in dual? Still better than a gold Xeon dual?
All the specs on the recommended PCs on the system requirements page say use xeons in HP computers. All of the 10 of the computers except the recommended laptop.
And yet most people I see in here are using i9s for their PT ultimate systems.
Computer shop told me i9 will load the software and plug-ins faster but that the xeons will be better overall and renders faster. And they don't even sell xeons so I'm thinking a crazy dual gold Xeon will be whey better?
Old 02-23-2022, 10:54 PM
abc1mce2's Avatar
Dominic
Done.
https://duc.avid.com/showthread.php?t=416854&page=3
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2 Bomber ADC
Dangerous 2Bus
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Build a PC for ProTools nige108 General Discussion 3 07-07-2015 03:53 PM
Protools has like a 4 second Lag when i hit play on my I7 build! broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 06-07-2010 12:19 AM
$600 to build a ProTools PC. Suggestions? Chaotic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 10-26-2009 07:57 PM
Protools Pc Build pingu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-09-2008 11:03 AM
Help me build my studio with protools Twin Cam General Discussion 3 11-20-2002 07:27 PM
