i want to swap my system from MacOs to Win. Now i need a little advice to buy the right stuff. I thought about: - Mainboard 299x or Z590 with thunderbolt - I9 Intel 10900K or 11900k - 32 GB Ram - M2. 2TB Drive - GT 1030 Graphic - Win 10 Pro what would you recomend ? Thx for your Help |
You should be golden!
Desktop: PT 2020.5 / Win11 / Intel 11th Gen i9 5.1GHz / 64Gb DDR4-3600 / Gigabyte Z590 Vision D / Focusrite LS56 Laptop: PT 2020.5 / Win10 / older HP ProBook with i7 quad / U-PHORIA UMC1820 Legacy (works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001 Click for audio/video demo |
Great thx a lot. But will it run with hdx?
Best Stefan |
Yes it should run HDX just fine. I have a 10th Gen. i9 10850K with a Gigabyte Z490 Vision D mobo and all is well. When building your system make sure you install Windows and get it running first before you install your HDX card (UAD2). If your using the internal graphics card you should be able to get the BOIS to post (viewable) immediately. When using a GPU card I had to re-seat it a few times before the BOIS would post (I can tell someone what I did if they run into any problems). You need to use a GPU card cause several plugins I use would not open (UI wasn't visible) when I used the internal graphics card so I had to use my GPU (You may or may not run into this problem). The HDX card for my build had to go in the 2nd PCIe slot or it wouldn't work if I remember correctly. I forget what slot my UAD2 card is in. I have my M.2 drive in the first M.2 slot so it's running off my CPU and not taking any of my six SATA lanes. All my UBS3 and USB2 ports are working fine. I'm not using the Thunderbolt 3 ports but I hear they work fine. Once you get everything running smoothly, please clone your system drive with Acronis or Macrium Reflect, Please do this ASAP. This will save you alot of frustration if your system starts acting funny or an Windows update breaks something. You can thank me later.
What is more relaxing than Music? Pro Tools Carbon is here! My HDX is on the way out ![]() Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 10.15.7 Hackintosh / 32GB of Rams Avid Carbon/HDX 2022.4 Ultimate - 16x16 - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (2) Universal Audio UAD2 Pci-E and Satellite USB Octo v.9.15.1 - SOLO 610 - Twin-finity Antelope Trinity - 10M Grace Design M905 Bricasti M7 (2) Lexicon PCM96 Burl B2 Bomber ADC Dangerous 2Bus Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Etc, etc, etc. |
Great!
Great thx a lot!!
![]() Quote:
Just an update on my system build. I recently decided to Hackingtosh my mobo to accommodate my PT Carbon purchase (With the blessing of moderator SOUTHSIDEMUSIC). I had no hiccups in the process and very few workarounds for total mobo functionality. One of the 2 ethernet ports doesn't work, (2.5Gigabyte ethernet port) I'm using wifi for internet access, and one of my Pci-e slots acts funky when populated. Other than that I'm a happy camper. MacOS 10.15.7 and PT are working beautifully as a unit and Carbon sounds fantastic. This mobo is golden no matter which OS you decide to use.
What is more relaxing than Music? Pro Tools Carbon is here! My HDX is on the way out ![]() Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 10.15.7 Hackintosh / 32GB of Rams Avid Carbon/HDX 2022.4 Ultimate - 16x16 - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (2) Universal Audio UAD2 Pci-E and Satellite USB Octo v.9.15.1 - SOLO 610 - Twin-finity Antelope Trinity - 10M Grace Design M905 Bricasti M7 (2) Lexicon PCM96 Burl B2 Bomber ADC Dangerous 2Bus Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Etc, etc, etc. Last edited by abc1mce2; 02-11-2022 at 04:46 PM. |
![]() Quote:
Dominic |
Is there any particular reason why i9 is aimed for as opposed to xeon processors in dual? Still better than a gold Xeon dual?
All the specs on the recommended PCs on the system requirements page say use xeons in HP computers. All of the 10 of the computers except the recommended laptop. And yet most people I see in here are using i9s for their PT ultimate systems. Computer shop told me i9 will load the software and plug-ins faster but that the xeons will be better overall and renders faster. And they don't even sell xeons so I'm thinking a crazy dual gold Xeon will be whey better? |
![]() Quote:
https://duc.avid.com/showthread.php?t=416854&page=3
Build a PC for ProTools | nige108 | General Discussion | 3 | 07-07-2015 03:53 PM |
Protools has like a 4 second Lag when i hit play on my I7 build! | broken81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 06-07-2010 12:19 AM |
$600 to build a ProTools PC. Suggestions? | Chaotic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 10-26-2009 07:57 PM |
Protools Pc Build | pingu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-09-2008 11:03 AM |
Help me build my studio with protools | Twin Cam | General Discussion | 3 | 11-20-2002 07:27 PM |
