Old 11-26-2021, 05:08 PM
noah330 noah330 is offline
Default importing audio click track - any advice on this?
I recently got a track someone did of an acoustic guitar without a click. Now they want to add drums, bass, etc....
Normally I would just go through and make a tempo map. Although this takes a lot of time.
I have Logic because it came with a bundle I bought with FCP. There is this adaptive tempo feature. I imported the audio file into there and it worked flawlessly.
I just muted my track and exported the file using the click being played during playback and it worked like a charm.
However, importing the audio file into PT and extracting tempo seems to be off just enough to drive me crazy. I could go back and beat map this, which would be pretty fast but I don't know if there's some simple step I'm missing.
I used Beat Detective to extract the timing data.
I have no desire to use Logic for anything else. I spent a few hours with it and really like PT flexibility better so please no 'just use Logic' type of responses please.
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Old 11-26-2021, 11:21 PM
ibbod0 ibbod0 is offline
Default Re: importing audio click track - any advice on this?
instead of importing the audio from logic, exporting midi from logic and import it into pro tools should import the tempo changes
Old 11-27-2021, 05:23 AM
Thanks. Would a midi have the tempo changes that the audio file has? I tried recording the click as midi in logic but couldn’t figure out how to do it.
All the tutorials I found referenced mixer buttons I don’t seem to have.
Instagram:
Old 11-27-2021, 01:55 PM
Tweakhead Tweakhead is offline
If you've already tempo-mapped it in Logic, then just creating an 8th note MIDI track the length of your session will give you what you want.
If it doesn't easily work for you to export that MIDI, then print the 8th note click (or any transient perc) to an audio track in Logic and then import the audio file into Pro Tools and Beat-Detective that.
Old 11-30-2021, 03:05 PM
Thanks so much. I pulled my source audio track into logic then made a midi track and played a little bit the length of my audio track.
Imported midi in pt and it asked me if I wanted the tempo information. Worked perfectly.
A great reason to own logic. Thanks again!
Instagram:
need advice importing 88k audio into a 96k session zapple Pro Tools 9 6 07-01-2011 09:12 AM
My audio track is recording my aux click track. bunderson Pro Tools M-Powered (Win) 5 09-15-2007 03:54 AM
importing audio to track nap_complex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-20-2005 05:39 AM
importing audio to track russell jack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-26-2004 10:12 AM
What comes after the click track??? Basic recording advice needed Dan M. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-05-2003 12:44 AM
