Re: Pro Tools 2021.10 on Mac
Yes, that's more than enough. No you don't need two drives. 1GB/s comes to 3472 tracks of 24bit/96kHz audio. That's probably enough? (ok, there's interface overhead etc, but even if you only get half the stated bandwidth, you get 1736 tracks.) For comparison, my old firewire 800 session drive had a real-life throughput of about 50MB/sec, which was enough for 173 tracks of 24/96, or 346 tracks of 24/48 (which is what i was & am using). So even back in 2009 we were in pretty good shape... here's how to do the math: 96000 samples/sec * 24bits/sample * 1byte/8bits = 288000 bytes/sec 1 GB = 1000000000 bytes (yes really, they use base 10 now for drive sizes) 1000000000 bytes / 288000 bytes/track = 3472.2 tracks
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies Last edited by huzzam; 11-20-2021 at 04:40 AM. Reason: tons of extra whitespace was added |
As you are starting to build out a system it’s important to do your research and qualify what is the most functional. If you think of your MBP as the brain of your set up, hosting your software, meaning Protools, plug-in’s and your VI’s. You will find it better to record your sessions to an external drive, a fast portable SSD will do. Research what is out there. You will then come to a point when using VI’s that the samples are so large, you will need another external SSD to store them. Then you will get to the point of an audio interface with AD to DA on it and the option for an external keyboard to trigger your VI’s. It is nice to hope for a portable solution and a MBP to solve all your production issues, but at this point the memory and software developers are not there yet. Running a fully loaded 7.1 with HDX3 , SSD’s and large RAM setups, with large sessions will eliminate any laptop at this point in time. Sent from my iPad using Tapatalk |
And a lot of folks can run Pro Tools on a MBP with little external crap, not everybody needs a Mac Pro/HDX system. |
Exporting sessions is much easier with a pocket SSD to bring to another location. Also it is always better to work to an external drive. In case a computer goes down.Always have and always take my laptop and plug it into other rigs running HDX via cables. Correct not everyone needs HDX, but have been doing this for along time and have seen to many issues where systems fail. Always need a back up. So don’t criticize me and tell me what I know. It’s excellent advice especially for some one starting out. Got it? Sent from my iPad using Tapatalk |
If you I want to export/move a session, sure stuff it on an external drive or USB stick. But none of that was being asked about. You might be projecting too much about your workflow that I suspect is unlikely to be relevant to new users. You are not helping folks a lot who are trying to get going and already confused as hell by wrong, out of date information from Avid. Let alone wandering off into silly land about HDX irrelevant stuff. Folks are asking *basic* getting started questions. |
#16
If you read the thread, someone mentioned that the new MBP was close to a 7.1 , it is not. That is what that comment was for. Don’t forget not everyone works on a laptop. Couldn’t get my work completed with out a large HDX system. Nor could many others in film or recording studios. Someone who is starting out needs to understand where it can go. If you are using PROTOOLS I would imagine they might be recording something in the future. Or creating with VI’s. It is a good idea to understand the paths that you could go down. It’s also important for them to do research on what and will not work. I have given my opinion on a correct path, you may not agree. However it may work for this person or not. I have found on my journey what works, that is what I will stick to and always work with. My apologies I thought this was a working professionals forum. Sent from my iPad using Tapatalk |
#17
In terms of reliability with PT, I've made it clear that it is nowhere near. Your phrase "My apologies I thought this was a working professionals forum" is deliberately provocative. This is a forum for beginners and hobbyists, as well as working professionals, and I'm sure you know it. Dominic |
#18
We don’t know at this time how powerful the new M1 Max is. All the software available is not up to date yet. Can you run a large session with everything that is available on previous OS or other machines. I wouldn’t be able to determine that until it is there. It would be incredible to have just a laptop that could. And yes you are correct. If someone wants to police the internet and determine that their way is only the right way and criticize a way that is functional. The op asked about hard drives. I will always run an external drive, at this time a SSD. If that person doesn’t great. Just giving an idea to think about for the future. What happens when there are to many VI’s and their data on the MBP and they try and add audio. What if the drive is close to full? This may happen as they move forward. Sent from my iPad using Tapatalk |
#19
M1max is a beast. Bank on it. I have a fully maxed out one.
It will not replace my 7.1 for my studio. But a new m1x Mac pro sure will. I can't have a laptop sitting around connected to my stuff in my studio. Looks stupid. Even though when it is fully qualified for protools it will be more than adequate for the job. Sent from my SM-G986U using Tapatalk |
#20
Good to hear. Can’t wait wait for the new Mac Pro, feel the same about the laptop, thanks for the info. Sent from my iPad using Tapatalk |
Pro tools 2021 on c-24 | CLASS-A-DUDI TAMIR | Pro Tools | 2 | 09-04-2021 03:07 PM |
pro tools 2021 : add mp3 | groovebrother | Pro Tools | 8 | 08-24-2021 05:29 AM |
Recommended iMac Specs for Pro Tools 2021.3 (Pro Tools STANDARD) BigSur Compatibility | Spoil the Child | macOS | 19 | 04-05-2021 05:35 PM |
