Old 10-27-2021, 09:35 AM
bifbangpow bifbangpow is offline
Default Kontact worked yesterday but not today?
I am running PT 2020.12 on an imac. I'm in the middle of a project with a tight deadline of this Friday and so of course something has gone wrong. When I create an instrument track and put Kontact in it, suddenly I can't get sound out of contact. It also seems unresponsive to my midi keyboard triggers. When I use any other plugin everything works fine. This is just a kontact issue.
Could really use help asap if someone could be so kind. Not finding answers myself.
my specs:
iMac 2020
3.8Ghz 8-core Intel core i7 processor
Catalina OS
ProTools 2020.12
Scarlett Focusrite
+ Saving to External Harddrive
http://MayMcDonoughMusic.com
Old 10-28-2021, 02:04 PM
Default Re: Kontact worked yesterday but not today?
anyone?
my specs:
iMac 2020
Catalina OS
ProTools 2020.12
Scarlett Focusrite
Old 10-28-2021, 02:23 PM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
What have you tried so far?
Other NI products working OK? Other non NI products? Other audio in general?
Tried trashing Pro Tools prefs? Tried trashing Kontakt prefs?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 10-28-2021, 06:49 PM
Check the MIDI channel in the Kontakt instrument you're using. Not the main Kontakt MIDI mapping but for the specific instrument you're using inside Kontakt. Set it to all/omni and see what happens.
Jack
QAPLA!
Old 10-28-2021, 08:15 PM
Tried it. Still no sound. The plugin does seem to recognize my midi keyboard after all. but still no wsound.
my specs:
iMac 2020
Catalina OS
ProTools 2020.12
Scarlett Focusrite
Old 10-28-2021, 11:09 PM
Marsdy Marsdy is offline
You could try resetting Kontakt’s outputs. Save your current configuration first if you’ve changed it from the default.
Instructions here:
https://spitfireaudio.zendesk.com/hc...takt-Libraries
Dave Marsden
UK
Old 10-29-2021, 05:05 AM
What specific version/revision of Kontakt are you running?
What library are you having a problem with? Stock that comes with Kontakt or third party?
Jack
QAPLA!
2018.3 won't launch. Worked fine yesterday DontLetMeDrown Pro Tools 2018 0 03-26-2018 06:36 PM
Pro Tools was working great yesterday but not today... phiffdawg Pro Tools 11 11 02-22-2016 05:01 PM
PT 7.4 with Ozone Keyboard worked fine for 4 months until yesterday ProToolsRules Pro Tools M-Powered (Mac) 2 01-31-2010 08:51 AM
s/pdif light blinks, no audio signal, .. and it worked yesterday. Ensemble and Mbox TheSetup Pro Tools M-Powered (Mac) 3 09-05-2009 10:58 AM
Help Pro Tools Won't Launch - Worked fine yesterday mnoxious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2007 09:17 PM
