Avid S1 and ethernet
Hi - Sorry if this is a dumb question, but would someone mind clarifying how to connect the Avid S1 to my computer (iMac)? I see that it requires an ethernet cable, but does this mean I have to run the cable from the router (which is two rooms away) to my workspace? Or do I just connect the computer and S1 with the cable? Thank you!
iMac (2020: 3.8 GHz 8-Core Intel Core i7, 32GB), OSX 14.1 (Sonoma), Pro Tools 2024, UAD Apollo 8, UAD-2 Quad Satellite DSP Accelerator, 2 x Lacie Thunderbolt SSD (250GB), Seagate Backup Plus Drive (4TB). |
Re: Avid S1 and ethernet
In my case, I've just got a switch that all the S1s/Dock are connected to, and the studio machine is also connected to that switch. My machine is hardwire ethernet only (no wifi) so the main router/gateway is also connected to this switch for external network access. This all seems to work fine.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
I see...thanks...my issue then is that my computer is connected to the network via wifi, not an ethernet cable...So I'll need to buy a lengthy cable...!
You should just be able to connect S1 directly to your iMac. See pg 7 in the Ref Guide.
No Ethernet in my home office, so my iMac is on WiFi. S1 is connected to a TP-Link TL-SG105 switch (cause I also have a Dock) and that's connected via adapter to one of the iMac's Thunderbolt ports (Carbon is using the Ethernet port).
• linkedin •
I read that on p.7. yes, but it also says "S1 cannot connect to your workstation computer using a wireless connection. A hard-wired network connection is required.". Am I misunderstanding? Thank you!
That just means S1 is not a wireless device - it needs a wired connection either directly to the computer or through a switch. Your computer can still use WiFi for an internet connection, but you'll need Ethernet between computer and S1.
• linkedin •
Ah, got you, that makes sense, thanks so much!
Good idea!
All working now, thanks!
Avid Artist Mix with USB 3 to Ethernet converter? | mmezrich | Artist Series | 1 | 03-13-2017 12:54 PM |
avid c24 ethernet issue | stanonbass | ICON & C|24 | 4 | 08-12-2016 09:21 PM |
Avid Ethernet Support (x64) could not be found. | Kinh | Pro Tools 11 | 2 | 07-10-2014 06:53 PM |
Avid Ethernet Support(x64) missing???? | 6505smith | Windows | 2 | 08-28-2013 12:34 PM |
What License Do I need to lock Avid MC5 with Pro Tools using Ethernet | kd_special | Post - Surround - Video | 9 | 02-16-2011 08:35 PM |
