HDX-2 System w Clocking Issues
Hi, I'm running a HDX-2 system on a Mac Pro. Our rig has 4 HD I/Os & a Sync I/O (2 I/Os going into each HDX Card). 2 HD I/Os (the 2 connected to the same card as the Sync) are able to lock up to the Sync I/O, but I can't get the 2 remaining I/Os to switch from their internal clocks. I've searched all over the DUC and Gearslutz to no avail, hence the forum post. Any suggestions? Let me know if I can add any more info!
https://www.hybridstudiosca.com/mastering/ |
Re: HDX-2 System w Clocking Issues
When you access the interface from the hardware page can you not select to clock from the sync I/O? is that your problem the SYNC I/O is not available as a clock? Do you have all the right cable connections from clock in/out etc. are the 2 non clocking interfaces daisy chained from the 2 working intertfaces? or how do you have them connected. are the 2 working interfaces and Sync I/O connected to the primary (1st) card in your system? Chris
-In the hardware interface the Sync is not listed as a clock source, however if I go to the session setup window I can select the Sync as the clock (which is what I've done). Once you select the Sync as the clock in the session setup window and go back to the hardware window, the clock source is blank/grayed out. Hopefully that makes sense, I can take some screen shots if you'd think that would help. -The cables are indeed hooked up correctly. Starting with Sync Loop Out to the 1st Interface's Loop In; 1st Loop Interface's Out to the 2nd Interface's Loop In; 2nd Loop Interface's Loop Out to the 3rd Loop Interface's Loop In; 3rd Interface's Loop Out to 4th Interfaces Loop In; and finally 4th Interface's Loop Out to the Sync Loop In. So basically the two non-clocking interfaces are daisy chained to the clocking interfaces. -And correct, the two interfaces that are clocking correctly are connected to the primary card along with the Sync I/O. If I were to guess I'd say the problem has something to do with only half the I/Os being connected to a card with the Sync I/O |
Sometimes it happens that one or more of my HDs will wake up stuck on internal, and a restart of Pro Tools usually fixes it.
I can't begin to tell you how many times I have accidentally connected the Loop Sync cables to the Word Clock ports. Yes, I'm a dope. But they're right next to each other… Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9 www.remotewest.com @RemoteWest |
So it does sound like a faulty HD interface is the cause? So 3 interfaces are working ok but one is stuck on internal sync? Is it still under warranty? Can you check the firmware version on them all? I think it's the same as previous interfaces! Load digi test from the Avid folder in applications and it will show the firmware and enable you to update to the latest etc. Chris
This sounds like a broken clock cable between interfaces #2 and #3.
Try taking interface #4 out of the equation and use another clock cable between interfaces #2 and #3 and if it suddenly recognizes three interfaces, you know what you need to do
I wish it was as easy as a bad cable, but definitely tried changing the cables with no success. Thanks for the idea though!
Clocking issues? | digidesigner | VENUE Live Sound Systems | 4 | 02-28-2010 03:08 PM |
ADAT clocking issues?? | sashbash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-21-2008 09:59 AM |
AES-SPDIF Clocking Issues | rattledaddy | Pro Tools TDM Systems (Mac) | 1 | 12-01-2007 10:14 PM |
Clocking issues between Digimax LT and 002. | iamlark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-14-2007 05:52 PM |
192 Re-clocking issues | Javier Carrion | Pro Tools TDM Systems (Mac) | 2 | 09-19-2003 06:31 AM |
