Old 11-06-2011, 02:52 PM
Dallas Taylor Dallas Taylor is offline
Default **PT10 Bug - Pencil Tool/Clip Gain
Found a bug today.
It appears that the pencil tool doesn't recognize clip gain. See video:
In order to fix this click, I had to reset the clip gain to zero, draw it out, then raise it back up.
DALLAS TAYLOR CAS/MPSE
/// Sound Designer/Mixer @ Defacto \\\ Twitter Facebook
Old 11-07-2011, 04:45 AM
Default Re: **PT10 Bug - Grabber Tool/Clip Gain
Originally Posted by Dallas Taylor View Post
Found a bug today.
It appears that the grabber tool doesn't recognize clip gain. See video:
See "what´s new" manual. Under certain conditions clip gain is rendered into the file when using handles. Maybe that is the case when destructively editing with the pencil as well? Not sure. Maybe it´s related..
Old 11-07-2011, 06:54 AM
Default Re: **PT10 Bug - Pencil Tool/Clip Gain
This is one of those things in PT10 that needs to "just work". I'm not going to go through multiple steps to simply draw out a tick.
Curious if anyone else has had this issue?
Old 11-07-2011, 09:33 AM
SDDP SDDP is offline
Just out of curiosity, why not hit "-" and go volume and pencil it out?
and how is clip gain more efficient over just going to volume and using smartools to draw/bring up or down volume?
Old 11-07-2011, 03:27 PM
We must be talking about 2 different things. I'm talking about clicks and pops that you can just draw right out of the waveform. Sounds like you're talking about volume automating?
As far as the pro/cons of clip gain, that's just a matter of taste. I prefer it since you don't have to constantly jump over to volume automation and hear your faders jumping around through a session.
Old 11-07-2011, 03:37 PM
My appologies, what I ment to say, why not just expand the wave form enough to see the pop/click and pencil it out?
Toggling between "T" & "R"?
Old 11-07-2011, 04:38 PM
Yeah, that's exactly what I was trying to do, but the clip gain is messing up the process. (see the video I linked)
Old 11-07-2011, 10:37 PM
KK Proffitt KK Proffitt is offline
Hmmm...maybe this is related to the pencil tool bug I posted in PT 10 Mac forum. When I try to pencil out a click, it makes the amplitude infinite so that I only see the left and right side of the waveform, never the apex. I'm using clip gain on a lot of these clips. Glad to see that someone else has pencil tool issues. I think something is definitely weird.
OK, just watched the video. I think we're seeing the same issue. Pencil tool shouldn't have anything to do with clip gain, or it should override clip gain. This latest behavior makes it unusable.
KK Proffitt
President, JamSync®
www.jamsync.com
www.tnfilmlocations.com
Old 11-07-2011, 11:05 PM
BTW, I think the point about it being related to clip gain is well taken in my case. I'm working on a 6 hour long forensic audio file taken from an MP3 recorder. Often, the audio has to be raised by 24 dB, de-noised, de-clipped and de-crackled using iZotope RX and then whatever thunks or clicks have to be dealt with manually. The pencil tool seems to be applying another 24 dB of gain to the drawn-in data, so in my case, it flies right out of the track. In my case, gong back to zero wouldn't work because I'd not be able to find it! In this case we're talking about the worst s/n ratio I've ever heard.
KK Proffitt
President, JamSync®
www.jamsync.com
Old 11-08-2011, 03:22 AM
dieffe dieffe is offline
I experienced the same bug: Pencil tool on waveform in a region (ops, clip! ) with clip gain and the gain is applied one more time after the drawing.
I'm used to consolidate the part of region I need to "pencil", and so this solve the problem, but this is pencil bug is extremely annoying.
OT, but one thing I think should be changed is the way consolidate works: consolidating only a part of a region should retain clipgain and metadata (or an option to choose this behavior should be available), matching the way duplicate AS plugin works.
Best
Davide
HTML code is On
Pencil Tool- Wave Form Editing in PT10 mauiboy macOS 2 06-13-2012 01:35 PM
Pencil tool and Clip Gain mattrixx Pro Tools 10 2 03-15-2012 09:43 PM
Clip Gain and Pencil - Bug tj_davies Pro Tools 10 3 02-06-2012 03:27 AM
PT10 Clip gain bug? dterry Windows 0 10-23-2011 12:11 PM
clip fixes with pencil tool davidp158 Tips & Tricks 3 03-29-2001 07:23 AM
