"DAE Loaded" hang - Old Problem, New User
Hello all. I have been using Pro Tools 7.0 with an Mbox 2 on my computer for a while, and it loaded great. I only use the default plug-ins and such that can with the PT 7.0 CD and nothing else, but lately, it just loads to DAE Loaded and will not go past it. I have:
- Deleted the folders identified in the General Troubleshooting FAQ. - Optimized as per the Digidesign site's parameters. - Updated ALL of the drivers in my system, even flashed the mobo to the latest firmware. - Updated PACE. - Uninstalled and reinstalled Pro Tools (through Control Panel > Add/Remove Programs) about 20 times or so. - Used every available USB port with my Mbox 2. - Tried different USB cables. I haven't turned off my network adapter because I need it for what I'm doing with Pro Tools. I use Pro Tools to use my microphone while DJing through Winamp, since I cannot go direct from the Mbox into Winamp. I have to use PT, send the sound out of the headphones jack into the line-in on my soundcard, then from there adjust volume and put it through Winamp. I am at my wits' end with this, and don't know what else to do. None of the other posts about this issue are about this version of PT, although I have tried anything that seemed to relate to my setup as I could in those posts to no effect. Below is my Sandra Hardware Report. My system is self-built. Any help getting this to finally stop would be greatly appreciated. And just to clear it up, I'm too poor for a version upgrade of PT, or I would happily get PT8. : ) -- Sandra Report -- SiSoftware Sandra Processor Model : AMD Athlon(tm) 64 X2 Dual Core Processor 5200+ Speed : 2.61GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 2x 1MB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size System Platform Compliance : AMD LIVE! Mainboard : ASUSTeK Computer INC. M2N32-SLI DELUXE BIOS : Phoenix Technologies, LTD ASUS M2N32-SLI DELUXE ACPI BIOS Revision 1201 (06/20/2007) Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.5GB DIMM DDR2 Chipset Model : AMD Athlon 64 / Opteron HT Hub Front Side Bus Speed : 2x 1GHz (2GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 373MHz (746MHz) Memory Module(s) Memory Module : OCZ OCZ2N800SR2G 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : OCZ OCZ2N800SR2G 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Adapter : NVIDIA GeForce 8800 GT (2x 112 SP 1.55GHz, 2x 512MB DDR3 2x972MHz, PCIe 2.00 x16) Graphics Processor Adapter : NVIDIA GeForce 8800 GT (2x112SP 1.67GHz, 2x512MB 2x972MHz) Storage Devices WDC WD800JD-00MSA1 80GB (SATA300, NCQ, 8MB Cache) : 75GB (C:) SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (D:) SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (E:) Logical Storage Devices Hard Disk (C:) : 75GB (NTFS) @ WDC WD800JD-00MSA1 80GB (SATA300, NCQ, 8MB Cache) Programs (D:) : 466GB (NTFS) @ SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Storage (E:) : 466GB (NTFS) @ SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Pro Tools LE (F:) : 479MB (CDFS) Optical Drive (G:) : N/A Optical Drive (J:) : N/A 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : ASUS MCP55 LPC Bridge LPC Legacy Controller 1 : ITE IT8716F Audio Device : Creative Labs SB0790 X-Fi XA Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASUS MCP55 IDE Disk Controller : ASUS MCP55 SATA Controller Disk Controller : ASUS MCP55 SATA Controller Disk Controller : ASUS MCP55 SATA Controller USB Controller 1 : ASUS MCP55 USB Controller USB Controller 2 : ASUS MCP55 USB Controller FireWire/1394 Controller 1 : ASUS TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1 SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2 Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : EPSON Stylus CX4200 Series (360x360, USB, Colour) Printer : Adobe PDF Converter (4000x4000, Colour) Scanners and Cameras Scanner : EPSON Stylus CX4100/CX4200 (USB) Network Services Network Adapter : NVIDIA nForce Networking Controller - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 2) Platform Compliance : x86 |
Re: "DAE Loaded" hang - Old Problem, New User
There might be something corrupt in the user permissions of windows itself. I'm sure there is something you can modiy to get what you need, but I have a quick fix that might work.
Create a new user in windows and log in to it, Try Pro Tools from there and see if it works. |
Unfortunately, it didn't work. I made sure to make the account an Admin account and restarted after creating it, but to no effect. Thank you for your reply though.
Sorry man, that's worked for me. It's the way it is with Pro Tools... everybody seems to need a unique solution.
Make sure if you have Internet Explorer 8 installed that you roll it back to IE7. Single most common cause of Hangs right now.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Nope running IE7 (would happily uninstall if I could).
Omni causing "Creating DAE object" hang on boot-up | sharp11 | Pro Tools HDX & HD Native Systems (Mac) | 3 | 03-04-2013 07:57 AM |
MC Control "eucon library is not loaded windows" | djmichaelwenz | Artist Series | 1 | 10-05-2012 07:11 PM |
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" | xfarre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-22-2011 07:37 AM |
PT 8 LE wont load after install --> stops at "DAE Loaded" | jmasengarb88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 11-20-2009 07:27 PM |
New Dell Laptop hangs on "DAE Loaded" PT8 Vista | Neil Miller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-16-2009 03:30 PM |
