Wire Harness and Tech Support
Just found out that my 002 is included in this batch with a bad wiring harness
Called Digi - sending a new part overnight via FedEx. That was easy! Wish me luck with the install of it ----- Zap!! LOL |
Re: Wire Harness and Tech Support
You know, I haven't even checked mine to see if its included. It just seems to be okay, but I will check ser# tonight to be sure.
And lets hope no ZAP!
soon to be back at it again... |
rememeber:
One connection at a time, One connection at a time, One connection at a time, One connection at a time, One con.........
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
One connection at a time? I am afraid to ask what that means?
Guess I will wait for the instructions, eh. I hope this is the fix of fixes - I am reading here that some have more probs after. |
There are 3 connections that need to be made. Jpoprock found out the hard way that if you don't put the new harness back the same as the old, you will fry your 002. So you remove one connector and put the appropriate connector on - in the same orientation. Do that 3 times and you're good to go. Very easy - just do proper housekeeping. No one else who cahnged the harnes ( and there have been many) had a problem.
Good luck.
Don't worry, if you have a screwdriver, and 30 minutes, you are set. When I did mine, I drew all sorts of pictures of where everything went thinking I'd screw it up. Turns out it was super easy and fixed my fader issue 100%.
Have fun Jason |
Thanks guys:)
Kit came this morning... will give it a go later tonihgt. Gulp! LOL |
All done. Pretty simple stuff. The plugs are a bitch to get off but LOL ... all seems well.
I noticed that fader 6 is jerky when it fades up from off. Kind of like fff fff fff ffffffffffffffffffff <this is all very quick> once it gets past less than a 1/4 of the way up it's clean? Any thoughts? |
Hi Guys,
Where do I find the list of serial no.s with the bad wiring harness problem? Cheers Dave S |
I just knew mine was by the way it was acting. I called Digi and the took half a second to verify that my unit was on the list.
Still need to find out whats wrong with the one fader |
New tech support tools - Tech Support Folder | DigiTechSupt | Technical Alerts | 0 | 08-07-2007 08:13 AM |
DigiTech Support: please help with power harness! | The Dubnicks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-28-2005 08:35 AM |
New wire harness, dead 002. What do I do now? | Blue Ridge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-29-2005 05:21 PM |
002r Wire harness problems? | barznbeats1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-29-2005 11:18 AM |
bad wire harness issue 002R Serial numbers | Blutus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-13-2004 04:15 PM |
