Old 11-24-2021, 08:08 AM
Default Re: Problems with HD native and MacMini M1
Sorry I cannot double-check for you as my HDN thunderbolt box is on another gig now. Just reading specs. They say it should work but if it does not, contact support.
Old 11-24-2021, 02:33 PM
bernstudios bernstudios is offline
I'm now on 10.6.1 with protools 2021.10 and HD driver 2021.10 but still no HD native to choose unfortunately..
Old 11-24-2021, 02:49 PM
You could try another TB cable/port, but I really think you should contact support at this time. They say it should work (which I cannot double-check in a timely matter) so let them help you further.
Old 11-25-2021, 04:35 AM
the thing is I have two mac minis, one M1 and an older quadcore.. on the quadcore with the same cable everything works fine just the M1 doesn`t work..
Old 11-25-2021, 05:09 AM
Dont know what to say. My box is on a gig now and at home I am using Apogee Symphony mkII via TB and despite adapter it is working. Will test HDN later if I still remember
Old 11-26-2021, 06:41 AM
thx+ if you have a chance to test HDN that would be awesome
Old 01-21-2022, 01:27 PM
bayview bayview is offline
Has this been solved? I'm running exact same spec and cannot get to run either.
Thanks!
Old 01-21-2022, 02:03 PM
Gremlin Gremlin is offline
Just a thought...make sure you do this:
https://avid.secure.force.com/pkb/ar...ation-on-macOS
Old 01-21-2022, 02:36 PM
Eric Lambert's Avatar
Very important.
Also, many people have had trouble with the HD Driver over the past few months. Some (like me) had to use the HD Driver Installer that was within the ProTools Installer folder as the separately downloaded installer exhibited the issue you're having. And some others simply needed to reinstall the driver a couple of times to get it to stick. Odd, yes, but that's how it worked for them.
As mentioned, your computer *should* work with that hardware. If the remedies mentioned here don't work, reach out to Avid. Their tech support dept is getting paid to handle issues like yours.
MBP or MacMini? Hanswurstlsepp macOS 8 06-01-2021 12:37 PM
New MacMini(i7), Mojave, PT 2018.12U, HD-Native littlesicily macOS 12 12-26-2018 06:03 PM
Can't Run 2 HDX Cards from MacMini Scott_Pilgrim Pro Tools HDX & HD Native Systems (Mac) 1 01-11-2018 12:33 PM
If MacMini has 5400 RPM HD how it will run PT LE 7.3? Marcos Vampa Tips & Tricks 7 05-08-2007 02:35 PM
CPU Upgrade or buy a MacMini djwilmer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-19-2005 07:55 AM
