BURL ADC with ADAT connection into MTRX Studio
Hey guys, I'm new to the AVID and PT products, so every day is a discovery for me.
I have already set up my MTRX studio with DVS and Dante Controller. I'm just having difficulty now connecting my BURL ADC via ADAT into the MTRX. I am moving and seeing all the possibilities inside the DADman, but nothing has worked so far. I already routed my analogue Outputs into my hardware chain ending on the Burl, but I cannot have that digital audio through the Burl to the MTRX. Any thoughts? PS: My Burl doesn't have the DANTE option, unfortunately. Thx |
Re: BURL ADC with ADAT connection into MTRX Studio
In any case, have you checked whether you have a green indication on the ADAT input in DADman, as shown in this example? Do you have any meter indications on the ADAT input in the routing window? Is the indicated samplerate in the routing window correct? And finally, have you sync'ed the Burl ADC with the MTRX Studio?
Jan Lykke Business Development Manager DAD - Digital Audio Denmark |
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
No, no indicator from ADAT input routing. Yes, the sample rate is correct for all devices (MTRX and DANTE) Sync - It's synced by Word Clock Here is the screen from my actual panel: https://www.dropbox.com/s/69qvur9c1c...53.26.png?dl=0 |
I'm using the BURL ADC B2 Bomber. I bought last year. Yes it have the TOS connection. Picture attached. I'm getting from the Burl to ADAT 1 IN on MTRX Studio Here is a print of the back of the equipments: https://www.dropbox.com/s/03bpw4pa2f...5.17.jpeg?dl=0 Thx |
The optical connection on the MTRX Studio is ADAT which is an 8-channel format. SPDIF is not compatible with ADAT, so you will not get this connection to work. An alternative is to use the AES output on the B2 and convert this to ADAT via some external converter.
The Bomber does have a Dante option card, that would probably be the simplest approach to take.
James Richmond https://www.jamesrichmond.com 2019 Mac Pro, 2022 Mac Studio Ultra Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro. Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com Latest Article: Auto-Bounce for Logic Pro Affiliate Links: Auto-Bounce by Tom Salta Dreamhost Web Hosting |
Another solution is to get the DANTE board for the Burl, right? |
Something like this will work? AES to DANTE https://reverb.com/uk/item/34752680-...io-adaptor-2x2 |
Or as uptheoctave suggests, go for the B2 Dante option if you can get one.
Connection Issues with MTRX Studio | Ooptron | Pro Tools | MTRX & MTRX Studio | 10 | 09-26-2023 02:34 PM |
Difference between MTRX and MTRX Studio? | snowplaysmusic | Pro Tools | MTRX & MTRX Studio | 4 | 11-26-2022 08:48 AM |
MTRX Studio tuning v MTRX SQP card | Goombot | Avid Pro Mixing General Discussion | 9 | 07-15-2021 11:00 AM |
MTRX Studio DADman-Network Connection Error | pablovius | Pro Tools | MTRX & MTRX Studio | 39 | 07-03-2021 10:50 PM |
Digi 002, Burl B2 bomber Adat? Please help | primomusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-28-2018 03:48 PM |
