Old 09-09-2021, 07:04 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default USB 3.0 hub recommendations for Mac - 2021
I've noticed a few usb related glitches, which seem to be from my powered USB hub. It's pushing 6-7 years old, so probably time to upgrade.
My setup:
2013 Mac Pro trash can
RME babyface pro
PT 2021.7
Logic X
I recently updated from an older version of PT, and added some more Softube plugins, but the system was stable for at least a month after those changes. Right now I am getting random ilok auth errors, audio drop outs, UPDD errors for my raven touchscreen and in some cases - the usb hub will just suddenly be turned off. So more than likely a failing power supply for the usb hub or the hub itself is just showing its age. One thing I despise about this hub is the power switch is a momentary button. So, every time it is unplugged, a momentary button needs to be pressed to turn it on. Very annoying because it's behind my desk.
Anyways, looking for a solid powered USB 3.0 hub, 10 ports or more, with no power switch at all, or a rocker switch that I can just leave on, so when I shut down my UPS, I don't need to reset it. Some of these new ones have "smart charging ports"... Like any new technology, I'm skeptical that it might cause other issues.
Any recommendations? Haven't shopped for these for a long time, I know when I bought this one, I went through 2 or 3 different brands before I got one that was reliable.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 09-09-2021, 07:45 AM
EGS's Avatar
EGS EGS is offline
Default Re: USB 3.0 hub recommendations for Mac - 2021
I recently picked up this one https://www.newegg.com/p/0J2-06Z5-00...9SIAV17E9Z0106 Works well for me.
Click for audio/video demo
Click for resume
Old 09-09-2021, 08:15 AM
Are the switches mechanically latching pushbuttons? If not, do they retain their last setting if the hub is disconnected from power?
- John
Old 09-09-2021, 12:52 PM
Well I was hoping I could wait to order one, but ended up going to micro center today, the problem was happening every 10 minutes and just too annoying to deal with any longer.
I bought this:
https://www.microcenter.com/product/...-power-adapter
At $60, its the most expensive usb hub I have ever bought. but, it has a rocker switch for power, seems solid and well built. So far, I haven't seen the UPDD connect/disconnect messages on my raven... which was the most common symptom. So fingers crossed, I'll post back my findings once I've put it through its paces.
- John
Old 09-09-2021, 01:36 PM
EGS's Avatar
EGS EGS is offline
Yes, they latch. It's set and forget.
Click for resume
Old 09-09-2021, 02:50 PM
uptheoctave uptheoctave is offline
IMHO non-rackmountable USB hubs are a total PITA.
Sedna do a 13 port hub for not a lot of money.
I have 3 of them in different parts of the studio, extended by active cables.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 09-09-2021, 08:17 PM
nst7 nst7 is offline
This one is also $60 and works great:
https://www.bhphotovideo.com/c/produ..._port_hub.html
Old 09-10-2021, 05:48 PM
melodydetective melodydetective is offline
Anyone know of one that will provide sufficient power to keep a 12” iPad going? I use the Sabrent one and it doesn’t have sufficient power to charge the iPad faster than it drains.
M2 Mac Studio Ultra 192/4; Lynx Aurora 16; PT Studio, Cubase, Logic, DP; Video Sync; Aja T-Tap; Metagrid Pro; TouchOSC; VEPro; Acoustic Samples, SM, AM, SF, EW OPUS, JFK, JFC, MTBF, TL;DR
Old 09-11-2021, 03:37 PM
Even the smaller iPads, I have always used the wall charger that came with them. Nothing else seems to charge fast enough.
- John
No SRC in 2021.3.1 JanuS Pro Tools 13 01-11-2022 06:52 AM
2021.6 and 2021.7 restart after exit NJsound.com Pro Tools 12 08-11-2021 01:45 PM
Downgrading from 2021.6 t0 2021.3 Mac M1 Leon77 Pro Tools 2 07-21-2021 09:43 AM
2021 TDM HD4 Win XP Sugarnutz Pro Tools TDM Systems (Win) 5 07-15-2021 12:34 PM
