Old 12-09-2007, 04:43 PM
mejolt mejolt is offline
Default Trying to find best Audio Interface for Pro Tools
I am new to Pro Tools. I have only used it at school but I want to get it for home use. I also need an interface that will let me connect my MIDI keyboard to my computer for use with GarageBand as well. I'm not doing live recording, just in-home project for now. I also have SoundTrack and Final Cut Express. Is there an interface that will work with all the above? Help! Thanks!
Old 12-09-2007, 05:31 PM
sunburst79 sunburst79 is offline
Default Re: Trying to find best Audio Interface for Pro Tools
The current 003 series should have MIDI ports, I believe but am not entirely certain the Mbox2 Pro has a Midi port. My advice is to buy a interface that supports your Input/output needs and then if need be buy a MIDI to USB converter.
Having gone the Original Mbox to 002 route I suggest a FW interface, 002, 002R, 003, 003R, Mbox2 Pro. The 002 series is discontinued but can be found used. I was never satisfied with my Mbox, My 002 is what I should have bought in the first place.
The 003's offer the most inputs and the 003 offers a control surface. The 003 will function as a standalone MIDI controller for a variety of Apps. You would have read the specs to find out if it works for Final Cut Express or Soundtrack. I know its supposed to work with LOGIC.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 12-10-2007, 04:42 AM
Phil Ogden Phil Ogden is offline
Whilst Firewire is generally regarded as a better connection option, I've had great results from my Mbox2 (better than a 002). If you don't need all those inputs/outputs, I recommend you check out one. It's got MIDI I/O connectivity, hardware monitoring and is considerably cheaper.
http://www.myspace.com/philogg
Unable to find audio interface Jala Pro Tools TDM Systems (Mac) 8 07-28-2008 09:36 PM
DAE cannot find audio interface (HELP) :confused: Davidwilson Pro Tools TDM Systems (Mac) 3 06-11-2008 06:18 AM
Unable To Find Audio Interface Rubicon Pro Tools TDM Systems (Mac) 2 03-11-2008 07:11 PM
Unable to find audio interface? Help ,Please spurboxer Pro Tools TDM Systems (Mac) 4 03-01-2006 07:09 AM
Pro Tools LE can't find its own Audio Interface (Digi001) audiomiditweaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-24-2003 01:35 AM
