Setup: Pro Tools Intro; Scarlett 18i8
Pro Tools Intro should be able to record up to 8 tracks simultaneously. I can record on interfaces 1 - 4, but not on interfaces 5 - 8. I've limited this example to Tracks 1, 2 and 5. I can hear Track 5 in the output monitor, but I cannot record it. (No levels show up for this track in the Edit Window.) Pictures of this simple setup are attached. Granted, the Focusrite Control only shows 4 Inputs; but I think that is because they are the only ones that have configuration options (whereas other inputs do not). (When I click "Settings" in Focusrite Control, there is no way to add Tracks 5 - 8.) Thanks for any help. |
This has nothing to do with track limits, Pro Tools Intro is limited to four physical inputs... the first four that appear on the interface. This is called out in the product specs.
Thanks for the quick reply.
The only specs I could find were not as detailed as your response - i.e., "only the first four interfaces; not 'any' four interfaces simultaneously." Thanks again. |
![]() Quote:
https://www.avid.com/pro-tools/comparison Hope that helps. Thanks Darryl for the help on this one. Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
![]() Quote:
This first <n> catches out folks using different versions of Pro Tools, it's not just Intro, I've long asked for Pro Tools to give the user a clue which IO ports are or are not usable. Like you would think that would be obvious and be user friendly. And now we have pretty color coding in the IO but still no usable/unusable IO status. |
Interfacing Issue with Focusrite Scarlett 18i8 | UberAubergine | Pro Tools 11 | 2 | 06-04-2019 08:46 PM |
PT's 2018 12.0 W/ Scarlett 18i8 | Songs4Christ | Third Party Interfaces | 7 | 04-15-2019 11:50 AM |
Clock issues with P12.8.3 and Scarlett 18i8 | estokes1958 | Pro Tools 12 | 15 | 02-03-2018 11:00 AM |
Crackles and Pops in PT 11.2.1 w/Scarlett 18i8 | BassGuyGG | Pro Tools 11 | 1 | 04-06-2017 11:18 AM |
Focusrite Scarlett 18i8 | kyluigi | Third Party Interfaces | 6 | 10-17-2013 08:14 AM |
