Old 12-28-2016, 07:17 PM
stevedresser83 stevedresser83 is offline
Default My inputs and outputs are no longer working (hardware issue)
On win 10, protools HD with the pci-e card and the OMNI. I came back from xmas vacation and booted everything up and my UAD card didn't work. I opened up computer to try a new pci-e slot for the UAD card and accidently took out my PT HD card. I simply plugged it back in no problem and booted up. I open up protools and none of my IO options are available. I've tried taking the UAD card completely out of the computer, rebooting. Rebooting the OMNI. Re seating the card again. Updating to protools 12.7 and 12.7hd driver. No clue what is going on but I can't use any outputs or inputs. Really weird... Any ideas?
Old 12-28-2016, 07:48 PM
Default Re: My inputs and outputs are no longer working (hardware issue)
i just noticed when im in protools and i go to setup the hardware tab or option is not even showing at all... Yet somehow if I power off my omni with protools open prompts come up saying "a timeout occured interacting with an audio interface" Never not seen the hardware option under setup completely missing. Not sure how to fix!
Old 12-28-2016, 08:57 PM
jjnssn jjnssn is offline
I would suggest delete all preferences and I/O files. Even consider uninstalling and reinstalling pro tools. I have had issues with I/O settings, however not what you've described. I do have issues where my Octo card won't be recognized by my system and I have to power down, pull the plug at the power supply and hold the power button on the case to discharge the board. Reboot then things are fine again.
Old 12-28-2016, 10:22 PM
uninstalling and reinstalling worked. Weirdest error ever!
Assigning sends, inputs, outputs not working in Pro Tools 11 dez811 Artist Series 4 08-02-2014 08:39 PM
MidiSport 4x4 Anniversary Inputs no longer recognized wrachilla Windows 1 11-27-2012 01:24 PM
Mbox 2 Pro Hardware Issue - My interface isn't working! acmitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-16-2010 12:20 PM
can't use inputs 1 and 2 because same as outputs wigglemeister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-08-2004 10:32 PM
18 inputs & outputs idjones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-28-2000 11:10 AM
