I'm trying to upgrade from Pro Tool 9.0.5 to Pro Tools 10. I bought an upgrade card. The product shows up fine on the My Products page of my Avid account and I have no problem downloading it, but every time I double click the finished download (it is a 2.15 GB .dmg file) I get an error message: Pro Tools 10 Installer not recognized (or more precisely: Pro_Tools_10_Installer not recognized). I've seen some posts elsewhere suggesting the download may not be complete but I've tried three times now and each time had the same result. I tried looking at the .dmg file in Disk Utility and it also pronounced it as unrecognisable. Can anyone help? Thanks very much. Phil Macbook Pro 2.66 Core i7 4GB RAM Mac OS X 10.7.2 |
![]() Quote:
Dd you trash the first download and empty trash before downloading again! Also try downloading on another computer maybe! Then drop it on a flash drive or DVD as a data file and copy to the mac etc, it can be downloaded on any computer mac or PC. Also try creating a new login account on your mac. See if that works. Make sure the .img and the desktop folder which is found in your user library, both have privileges set to read and write, you can right click to get info then check privileged are set to read write for admin and you, if not unlock at the bottom of the window and make the changes to read write then re lock, then log out of the mac and back in, then try mounting the img. That's all I can think of at the moment. Chris
Thanks, Chris.
I've finally identified the problem. It seems my new router (a BT Business Hub) has a 2GB cap on file download! The files I had been downloading were showing as 2.147 GB which I assumed was complete. I changed back to my old router and tried again and this time the file was 2.26 GB. The .dmg file opened nomally and I then installed Protools 10 only to find that it does not see my ilok! I can see that there are quite a few threads about this so I'll move on to solving the next problem. Thanks for your help. Phil |
Just an update to my last post to say that the ilok problem was because I'd forgot to update the ilok software and install the new licence!
Having done that ProTools 10 is running perfectly and I'm pleased to say all virtual instruments including the AIR expansion pack are fine too. First impressions are good... |
![]() Quote:
Glad you got it sorted!! Chris
Free PT10 upgrade download, is it full installer or do I run PT9 first? | skiman123 | Pro Tools 10 | 3 | 02-21-2012 11:31 AM |
Pro Tools 10 installer not recognized | CalebB | macOS | 3 | 11-15-2011 03:13 PM |
How do i get a pro tools 8 le installer download? | Jack Green | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-05-2011 12:38 AM |
Pro Tools 8.0 HD Installer Download | ChrisMitchell | Pro Tools TDM Systems (Mac) | 4 | 04-12-2011 10:25 AM |
Pro Tools 7.4 not recognized/unable to upgrade | Jay_uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-22-2009 11:59 PM |
