Old 06-14-2010, 10:21 AM
digidesigner digidesigner is offline
Default Whats up with old or no Venue installers for digi distr. plugins?
I discovered today, when doing some plugin update management that there are no Venue installers for many plugins and then most that have installers for Venue are like vers. 7.3 while there are 8.0 versions available for Pro Tools for Windows. Why is that so and should we actually be discarding these 7.3 Venue installers and manually installing 8.0 win versions instead?
Old 06-15-2010, 01:50 PM
Avid Pro Mixing Support's Avatar
Avid Pro Mixing Support Avid Pro Mixing Support is offline
Default Re: Whats up with old or no Venue installers for digi distr. plugins?
VENUE plug-ins are only updated at major releases, and even then they typically lag behind Pro Tools plug-in versions by at least one version. If you look at the plug-ins that came with 2.8 and 2.8.1 you will notice that most are 7.4 or 7.3 versions. It is very likely that the only difference between a 7.4 plug-in and a 8.0 plug-in is the version number itself. If there are important fixes in a specific release then we will update that plug-in, but otherwise it may be a while before you see a "current" release version.
In general we do not recommend installing the Pro Tools versions of any plug-in (unless there is no VENUE installer available). There could be compatibility issues with some plug-ins that were not specifically tested with VENUE. If there is a VENUE installer you can be assured that it was tested to work with VENUE (either by us or the third party).
Another issue is that a Plug-in that is installed outside of the VENUE software will not show up in the "Previous Installs" list, and therefore can't be quickly reinstalled from a cached version.
-Rich
Old 06-16-2010, 03:06 PM
Hi Rich, thanks for clearing this out for me.
Whats up with Digi plug installers? digidesigner VENUE Live Sound Systems 5 03-05-2012 04:26 PM
Digi Approved vocal tune plugins - whats available Johnrg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-16-2009 01:18 PM
Digi support: Can I download newer updates for third party plugins than whats posted? Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-06-2009 11:41 AM
Which Digi Plugin Installers? innesireinar Pro Tools TDM Systems (Mac) 4 12-19-2008 04:53 PM
Mbox 2 Factory Plugins, where are its installers?? Amnesiac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-12-2008 02:09 PM
