Old 07-28-2007, 06:02 PM
duskb duskb is offline
Default 192 outputs not working right?
While setting up a mix one of my 192's lost its analog output capabilty.
When I go to the I/O menu for this particular 192 all I have as output options are "Optical" and "Digital", no "Analog". The Input card seems to be working fine and I do see LED indicators on the OUTPUT meter showing signal is present.
This is not a Digital card. Why is PT not seeing this as an Analog card?
FYI I tried using known digilink cables and tossing the pref's just in case this was a software problem. Did I miss anything?
Dusk
Dusk Bennett
Artist Development/Technical Services/Educator
Los Angeles Ca
"Award Winning Work, Every time..."
www.duskbennett.com
Old 07-28-2007, 07:03 PM
studiojimi's Avatar
studiojimi studiojimi is offline
Default Re: 192 outputs not working right?
this happened to me today too at 192 when returning to my 192 after visiting an 88.2 session for a minute
i rebooted the software and the 192 and all was well
i suspect the switching back and forth after being at 88.2 or another freak
it felt like that was the issue..could be wrong
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 07-29-2007, 12:23 AM
Hmmm...well I havent been at 88 anytime recently. I also trashed the prefs and rebooted as well. Still no luck.
Dusk
Dusk Bennett
Los Angeles Ca
www.duskbennett.com
Old 07-29-2007, 12:43 AM
AKA AKA is offline
I had a similar situation.
After talking to Digi UK, and a moment before sending the unit to service, they recommended i open the interface and check the node that is connected to the analog card in the 192.
Shockingly - it was not connected properly. I have not moved the interface, it was sitting in a rack since i bought it... how it happened ? i have no idea. BUT plugging the node back into the card solved that issue.
DesignInSound
Old 07-29-2007, 02:45 PM
Well I tried this too, I even moved the card to the expansion slot eliminating the main harness completely. Still no success. I've been tempted to swap cards between my working 192's but it would require a major effort to do this and I'm in the middle of a mix at the moment. Kinda bad timing for this to go bad.
I hope this card isnt bad. I have no idea how something can go bad without ever moving an inch.
Dusk
Dusk Bennett
Los Angeles Ca
www.duskbennett.com
Outputs not working theberzh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-15-2013 02:49 PM
MBox Pro 3 Outputs not working xkleenexk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-05-2012 04:10 PM
001 Outputs not working?!!? nerdyrocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 06-05-2003 06:44 AM
Digital outputs not working qbert1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-10-2002 04:52 PM
Analog outputs 3-8 still not working paganini12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-10-2001 05:07 AM
