Old 05-27-2015, 02:05 PM
SCG1 SCG1 is offline
Default Clip slide duplicates & groups clips
Note: I initially posted this under "Getting Started" thinking I was probably just missing something obvious, but I now believe this is a bug with PT11, and for the way I am trying to use it it's absolutely crippling. Any help appreciated:
I like to keep things simple and organised so I've named and cleaned up all my clips with names such as "Drums-Verse", "Drums-Chorus", "Bass-Verse", etc.
All I want to do is slide clips around the timeline, for example to insert enough space to add an intro.
Sounds basic, right?
Wrong!
I select all my clips, click-hold, and drag to where I want to slide them.
It works, except what it does is a) create new clips (for ex. "Drums-01") and b) it groups all the clips together (i.e. if I select "Drums-Verse"-"Drums-Chorus"-"Drums-Verse2"-"Drums-Chorus" - 4 neatly named clips - and I slide them, it'll not only slide them but also group them as one new "Drums-01" clip)
AARRGGHHH!!!
Please help - I'm about through my computer out the window!
Thank you in advance.
Just to clarify, these are the methods I've used:
- select (shift-click) multiple clips, click-hold and drag to new location to move them
- select multiple clips, cut, insert cursor at start of new location and paste
- select multiple clips and Edit / Shift
- also select multiple clips and Edit / Repeat (for ex. if I want to repeat the verse-chorus clips to verse-chorus-verse-chorus)
- also select multiple clios and Edit / Duplicate (same as above)
In all these cases I get the same problem, i.e. instead of my clips getting moved or copied, the clips are consolidated into a NEW clip.
Actually this happens on some of my tracks, but not others - go figure!!!
PS: I am using MIDI tracks.
I think this is a bug in PT11 cause I used to do the same thing in previous versions and did not have the problem before. I'm just amazed that I can't find any other reports of this problem!?... Anyone else?...
using ProTools 11.3.0 / Digi 003 Rack + / Mac OS X Yosemite 10.10.3
Why are my (midi) clips changing during a slide? YYR123 macOS 2 06-02-2015 01:53 PM
Clip slide duplicates & groups clips SCG1 Getting Started 4 05-28-2015 12:55 PM
Possible Bug: Clip slide (option H) values not exact DEastman Pro Tools 11 3 03-16-2014 03:25 PM
Region Groups-->Clip Groups Import File Menu Not working minister Pro Tools 11 0 01-06-2014 11:23 AM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
