Curious why +4 is considered the professional level. I think I understand the difference but which LE interfaces put out which level - I seemed to be able to find every spec on the interfaces aside from that.
+4 is usually a balanced connection making it less spectacle to noise and it can run long distances.
-10 is usually unbalanced and not able to drive a long cable
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
When you say long are you talking about like from a recordist booth down to a board?
![]() Quote:
The telephone industry is largely responsible for many of the standards used in professional audio. Another good example is that the voltage used for transmission in telephone systems is +48VDC (the battery at the switching station voltage)... the same as the voltage level for phantom powered microphones. +4 dB is considered by many to be the de facto audio level for professional grade equipment, this equates to 1.23 Vrms into a 50 Ohm load. Thus, as pointed out in the previous post, allows for longer transmission lines, less susceptibility to noise (although this isn't quite accurate, it simply lowers the potential noise floor, and thus gives a better signal to noise ratio). Since digital systems represent level changes via the number and status of bits that used to encode the data, voltage level has become less relevant and descriptive of the dynamics of a system as a 24 bit system has far more dynamic range potential than an 8 or 16 bit system. Hence the reason that many digital-based systems don't include the "0 dB" reference level - it's a moving target depending upon bit depth. It's more important to understand the noise floor and dynamic range within a system.
“What fresh hell is this?” - Dorothy S. Parker |
You will sometimes see the "dBFS" meaning "decibel full scale". 0 dBFS is max level, full scale. Anything higher will clip.
Yes, many standards came from early telephone company work since their goal was to send audio over very long distances with low noise and low distortion. That is where 600 ohms and balanced wiring came from. In fact, some even recommend twisted dry pair as a professional audio interconnect instead of shielded cable. In Europe, where 48VDC phantom power was developed, the ring voltage is 60-75VAC in most countries. No connection to the development of microphone phantom power. In 1966, Neumann GmbH of Berlin, Germany, presented a new type of transistorized microphone to the Norwegian Broadcasting Corporation, NRK. Norwegian Radio had requested phantom-powered operation. Since NRK already had 48V available in their studios for their emergency lighting systems, this voltage was therefore used for powering the new microphones (model KM 84), and is the origin of 48-V Phantom Power. http://en.wikipedia.org/wiki/Phantom_power
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
![]() Quote:
Preamp into 003...+4dBu or -10dBV? | FierceBrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-01-2010 06:48 AM |
+4dbu / 0VU | niros | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-06-2007 07:16 PM |
+4dBu or -10dBv ??? | micline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-03-2005 09:58 AM |
+4dBu? -10dBV? | Mark_Knecht | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 05-20-2002 09:21 AM |
issue with -10dbv and +4dbu | usinare | Pro Tools TDM Systems (Mac) | 2 | 07-24-2001 08:55 AM |
