Old 07-24-2001, 08:14 AM
usinare usinare is offline
Default issue with -10dbv and +4dbu
i am running the outputs of my triton keyboard to the 888/24 interface. the signal level is low. i was told the triton outputs at -10dbv and the 888 inputs at +4. how can i solve this problem. thanks.
Old 07-24-2001, 08:44 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is online now
Default Re: issue with -10dbv and +4dbu
For openers, I would try turning up the 888-24's input trim pots. If that isn't enough, you can change a jumper on the inside to operate at an overall -10 reference.
This is all explained in the manual.
My preference is to leave 888s strapped for +4 but to run them with the output trimmers reduced and the input trims increased because most gear doesn't really have enough headroom to operate at +4.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 07-24-2001, 08:55 AM
Mark Wheaton Mark Wheaton is offline
the better bet is to buy a -10 to +4 box (DI) a good one is the ebtech Line Leveler. they come in 2 channel and 8 channel versions. Plug -10 1/4 inch jack into -10 slot and a 1/4 inch TRS jack into +4 and from there into your 888.
-10 & +4dbu breaktheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-19-2010 03:34 AM
Preamp into 003...+4dBu or -10dBV? FierceBrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-01-2010 06:48 AM
+4dbu / 0VU niros 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-06-2007 07:16 PM
+4dBu or -10dBv ??? micline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-03-2005 09:58 AM
+4dBu? -10dBV? Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 05-20-2002 09:21 AM
